Ir para o conteúdo principal
Nokia 6086 Logic Board Replacement
O que você precisa
  1. Nokia 6086 Logic Board Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6086 Logic Board Replacement: passo 2, imagem 1 %32 Nokia 6086 Logic Board Replacement: passo 2, imagem 2 %32 Nokia 6086 Logic Board Replacement: passo 2, imagem 3 %32
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6086 Logic Board Replacement: passo 3, imagem 1 %32 Nokia 6086 Logic Board Replacement: passo 3, imagem 2 %32 Nokia 6086 Logic Board Replacement: passo 3, imagem 3 %32
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6086 Logic Board Replacement, Upper Back Cover: passo 4, imagem 1 %32
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
    Pergunte ao FixBot
    Comentar
  5. Nokia 6086 Logic Board Replacement: passo 5, imagem 1 %32 Nokia 6086 Logic Board Replacement: passo 5, imagem 2 %32
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6086 Logic Board Replacement: passo 6, imagem 1 %32 Nokia 6086 Logic Board Replacement: passo 6, imagem 2 %32
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6086 Logic Board Replacement: passo 7, imagem 1 %32 Nokia 6086 Logic Board Replacement: passo 7, imagem 2 %32 Nokia 6086 Logic Board Replacement: passo 7, imagem 3 %32
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
    Pergunte ao FixBot
    Comentar
  8. Nokia 6086 Logic Board Replacement, Base of The Phone: passo 8, imagem 1 %32 Nokia 6086 Logic Board Replacement, Base of The Phone: passo 8, imagem 2 %32
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Nokia 6086 Logic Board Replacement: passo 9, imagem 1 %32 Nokia 6086 Logic Board Replacement: passo 9, imagem 2 %32
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
    Pergunte ao FixBot
    Comentar
  10. Nokia 6086 Logic Board Replacement: passo 10, imagem 1 %32 Nokia 6086 Logic Board Replacement: passo 10, imagem 2 %32
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
    Pergunte ao FixBot
    Comentar
  11. Nokia 6086 Logic Board Replacement, Logic Board: passo 11, imagem 1 %32 Nokia 6086 Logic Board Replacement, Logic Board: passo 11, imagem 2 %32
    • Remove the logic board from the back cover of the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Andrea
Membro desde: 04/15/10
70 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 26-30, Regan Spring 2010 Membro de Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 42
Ao todo: 2,041
