Ir para o conteúdo principal
Nokia 6085h Front LCD Display
O que você precisa
  1. Nokia 6085h Front LCD Display, Battery: passo 1, imagem 1 %32
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Front LCD Display: passo 2, imagem 1 %32
    • Remove the phone's battery.
  3. Nokia 6085h Front LCD Display, Front LCD Display: passo 3, imagem 1 %32 Nokia 6085h Front LCD Display, Front LCD Display: passo 3, imagem 2 %32 Nokia 6085h Front LCD Display, Front LCD Display: passo 3, imagem 3 %32
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
  4. Nokia 6085h Front LCD Display: passo 4, imagem 1 %32 Nokia 6085h Front LCD Display: passo 4, imagem 2 %32
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
  5. Nokia 6085h Front LCD Display: passo 5, imagem 1 %32 Nokia 6085h Front LCD Display: passo 5, imagem 2 %32 Nokia 6085h Front LCD Display: passo 5, imagem 3 %32
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Nokia 6085h Front LCD Display: passo 6, imagem 1 %32
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Nokia 6085h Front LCD Display: passo 7, imagem 1 %32 Nokia 6085h Front LCD Display: passo 7, imagem 2 %32 Nokia 6085h Front LCD Display: passo 7, imagem 3 %32
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
Conclusão
Brett Balcer
Membro desde: 10/04/10
240 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-46, Amido Fall 2010 Membro de Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,101
