Ir para o conteúdo principal
Nokia 6030 Keypad Replacement
  1. Nokia 6030 Keypad Replacement, Battery: passo 1, imagem 1 %32 Nokia 6030 Keypad Replacement, Battery: passo 1, imagem 2 %32 Nokia 6030 Keypad Replacement, Battery: passo 1, imagem 3 %32
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6030 Keypad Replacement: passo 2, imagem 1 %32 Nokia 6030 Keypad Replacement: passo 2, imagem 2 %32 Nokia 6030 Keypad Replacement: passo 2, imagem 3 %32
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6030 Keypad Replacement, SIM Card: passo 3, imagem 1 %32 Nokia 6030 Keypad Replacement, SIM Card: passo 3, imagem 2 %32 Nokia 6030 Keypad Replacement, SIM Card: passo 3, imagem 3 %32
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6030 Keypad Replacement: passo 4, imagem 1 %32
    • Use your finger to close the metal cage.
    Pergunte ao FixBot
    Comentar
  5. Nokia 6030 Keypad Replacement, Front Cover: passo 5, imagem 1 %32 Nokia 6030 Keypad Replacement, Front Cover: passo 5, imagem 2 %32 Nokia 6030 Keypad Replacement, Front Cover: passo 5, imagem 3 %32
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6030 Keypad Replacement: passo 6, imagem 1 %32 Nokia 6030 Keypad Replacement: passo 6, imagem 2 %32
    • After removing the top cover, turn the phone over so the screen is facing upwards.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6030 Keypad Replacement: passo 7, imagem 1 %32 Nokia 6030 Keypad Replacement: passo 7, imagem 2 %32 Nokia 6030 Keypad Replacement: passo 7, imagem 3 %32
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
    Pergunte ao FixBot
    Comentar
  8. Nokia 6030 Keypad Replacement, Keypad: passo 8, imagem 1 %32 Nokia 6030 Keypad Replacement, Keypad: passo 8, imagem 2 %32
    • Gently pull the rubber away from the front screen and the buttons will detach from the plastic case.
    Pergunte ao FixBot
    Comentar
  9. Nokia 6030 Keypad Replacement: passo 9, imagem 1 %32 Nokia 6030 Keypad Replacement: passo 9, imagem 2 %32
    • Remove old keypad and replace it with new keypad.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 23-63, Johann Spring 2010 Membro de Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 60
Ao todo: 3,219
