Ir para o conteúdo principal
Nokia 6010 Charger Connector Replacement
O que você precisa
  1. Nokia 6010 Charger Connector Replacement, Battery: passo 1, imagem 1 %32 Nokia 6010 Charger Connector Replacement, Battery: passo 1, imagem 2 %32 Nokia 6010 Charger Connector Replacement, Battery: passo 1, imagem 3 %32
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6010 Charger Connector Replacement: passo 2, imagem 1 %32 Nokia 6010 Charger Connector Replacement: passo 2, imagem 2 %32
    • Lift the battery near the bottom and pry up.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6010 Charger Connector Replacement, SIM Card: passo 3, imagem 1 %32
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6010 Charger Connector Replacement, Keypad: passo 4, imagem 1 %32 Nokia 6010 Charger Connector Replacement, Keypad: passo 4, imagem 2 %32
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
    Pergunte ao FixBot
    Comentar
  5. Nokia 6010 Charger Connector Replacement: passo 5, imagem 1 %32
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: passo 6, imagem 1 %32 Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: passo 6, imagem 2 %32
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6010 Charger Connector Replacement: passo 7, imagem 1 %32 Nokia 6010 Charger Connector Replacement: passo 7, imagem 2 %32 Nokia 6010 Charger Connector Replacement: passo 7, imagem 3 %32
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
    Pergunte ao FixBot
    Comentar
  8. Nokia 6010 Charger Connector Replacement, Logic Board: passo 8, imagem 1 %32 Nokia 6010 Charger Connector Replacement, Logic Board: passo 8, imagem 2 %32
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
    Pergunte ao FixBot
    Comentar
  9. Nokia 6010 Charger Connector Replacement: passo 9, imagem 1 %32 Nokia 6010 Charger Connector Replacement: passo 9, imagem 2 %32 Nokia 6010 Charger Connector Replacement: passo 9, imagem 3 %32
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
    Pergunte ao FixBot
    Comentar
  10. Nokia 6010 Charger Connector Replacement, Charger Connector: passo 10, imagem 1 %32 Nokia 6010 Charger Connector Replacement, Charger Connector: passo 10, imagem 2 %32 Nokia 6010 Charger Connector Replacement, Charger Connector: passo 10, imagem 3 %32
    • Insert a spudger tool between the phone casing and the charger connector.
    • Pry the key away from the phone gently.
    • Be careful not to bend the metal leads while handling the power key.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 14-45, Regan Winter 2010 Membro de Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 4,624
