Ir para o conteúdo principal
Nokia 3310 3G Screen Replacement
O que você precisa
  1. Nokia 3310 3G Screen Replacement, Battery: passo 1, imagem 1 %32 Nokia 3310 3G Screen Replacement, Battery: passo 1, imagem 2 %32
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  2. Nokia 3310 3G Screen Replacement: passo 2, imagem 1 %32 Nokia 3310 3G Screen Replacement: passo 2, imagem 2 %32
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
    Pergunte ao FixBot
    Comentar
  3. Nokia 3310 3G Screen Replacement, Frame: passo 3, imagem 1 %32 Nokia 3310 3G Screen Replacement, Frame: passo 3, imagem 2 %32 Nokia 3310 3G Screen Replacement, Frame: passo 3, imagem 3 %32
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
    Pergunte ao FixBot
    Comentar
  4. Nokia 3310 3G Screen Replacement, Motherboard: passo 4, imagem 1 %32 Nokia 3310 3G Screen Replacement, Motherboard: passo 4, imagem 2 %32 Nokia 3310 3G Screen Replacement, Motherboard: passo 4, imagem 3 %32
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
    Pergunte ao FixBot
    Comentar
  5. Nokia 3310 3G Screen Replacement, Screen: passo 5, imagem 1 %32 Nokia 3310 3G Screen Replacement, Screen: passo 5, imagem 2 %32 Nokia 3310 3G Screen Replacement, Screen: passo 5, imagem 3 %32
    • With the motherboard removed, the only thing holding the screen into place is the snap plug on the back of the motherboard.
    • Using a spudger, leverage the top snap up to disconnect it (photo shows motherboard rotated 90 degrees counterclockwise).
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team S3-G3, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G3, Peak Fall 2018
UMASSD-PEAK-F18S3G3
3 Membros
Autoria de 16 guias
4Comentários do guia
If you can break the screen without taking it apart, then you must not be human
Feyrowan - Responder Compartilhar
The Cylons are greeting you.
M. H. - Responder Compartilhar
Thank you!
I dont have cash for a new one,
but i could fix my old one.
There was soup on the display inside,
cleaned it, screen is clear now.
Yeay!
fred - Responder Compartilhar
Where could I get a replacement screen?
Secret - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 29
Últimos 30 dias: 78
Ao todo: 2,657
