Ir para o conteúdo principal
Nokia 3100b Microphone Replacement
O que você precisa
  1. Nokia 3100b Microphone Replacement, Battery: passo 1, imagem 1 %32
    • Make sure your phone is turned off.
    Pergunte ao FixBot
    Comentar
  2. Nokia 3100b Microphone Replacement: passo 2, imagem 1 %32
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Pergunte ao FixBot
    Comentar
  3. Nokia 3100b Microphone Replacement, SIM Card: passo 3, imagem 1 %32
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Pergunte ao FixBot
    Comentar
  4. Nokia 3100b Microphone Replacement: passo 4, imagem 1 %32
    • Retrieve your SIM card.
    Pergunte ao FixBot
    Comentar
  5. Nokia 3100b Microphone Replacement, Microphone: passo 5, imagem 1 %32
    • Press the black tabs to release the front cover from the phone.
    Pergunte ao FixBot
    Comentar
  6. Nokia 3100b Microphone Replacement: passo 6, imagem 1 %32
    • Remove the front cover from the phone.
    • Set the front cover as indicated, aside.
    Pergunte ao FixBot
    Comentar
  7. Nokia 3100b Microphone Replacement: passo 7, imagem 1 %32 Nokia 3100b Microphone Replacement: passo 7, imagem 2 %32
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
    Pergunte ao FixBot
    Comentar
  8. Nokia 3100b Microphone Replacement: passo 8, imagem 1 %32 Nokia 3100b Microphone Replacement: passo 8, imagem 2 %32 Nokia 3100b Microphone Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Note the location of the microphone.
    • Use tweezers to remove the microphone from the phone's base.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 29-64, Johann Spring 2010 Membro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 2,462
