Ir para o conteúdo principal
Nokia 2115i Motherboard Replacement
O que você precisa
  1. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: passo 1, imagem 1 %32 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: passo 1, imagem 2 %32 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: passo 1, imagem 3 %32
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
    Pergunte ao FixBot
    Comentar
  2. Nokia 2115i Motherboard Replacement: passo 2, imagem 1 %32 Nokia 2115i Motherboard Replacement: passo 2, imagem 2 %32
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
    Pergunte ao FixBot
    Comentar
  3. Nokia 2115i Motherboard Replacement, Faceplate: passo 3, imagem 1 %32 Nokia 2115i Motherboard Replacement, Faceplate: passo 3, imagem 2 %32 Nokia 2115i Motherboard Replacement, Faceplate: passo 3, imagem 3 %32
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
    Pergunte ao FixBot
    Comentar
  4. Nokia 2115i Motherboard Replacement, Removing the Keypad: passo 4, imagem 1 %32 Nokia 2115i Motherboard Replacement, Removing the Keypad: passo 4, imagem 2 %32
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
    Pergunte ao FixBot
    Comentar
  5. Nokia 2115i Motherboard Replacement, Removing the Motherboard: passo 5, imagem 1 %32 Nokia 2115i Motherboard Replacement, Removing the Motherboard: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
    • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
    • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
    • Use a size T6 Torx screwdriver to remove each of these 6 screws.
    Pergunte ao FixBot
    Comentar
  6. Nokia 2115i Motherboard Replacement: passo 6, imagem 1 %32 Nokia 2115i Motherboard Replacement: passo 6, imagem 2 %32 Nokia 2115i Motherboard Replacement: passo 6, imagem 3 %32
    • To remove the motherboard, lift it up and off the phone.
    • Note: The screen will still be attached to the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Shane
Membro desde: 09/30/10
80 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-38, Forte Fall 2010 Membro de Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 3,345
