Ir para o conteúdo principal
Nokia 1100b RH-36 Screen Replacement
O que você precisa
  1. Nokia 1100b RH-36 Screen Replacement, Battery Cover: passo 1, imagem 1 %32 Nokia 1100b RH-36 Screen Replacement, Battery Cover: passo 1, imagem 2 %32
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia 1100b RH-36 Screen Replacement, Battery: passo 2, imagem 1 %32
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
    Pergunte ao FixBot
    Comentar
  3. Nokia 1100b RH-36 Screen Replacement, Front Cover: passo 3, imagem 1 %32 Nokia 1100b RH-36 Screen Replacement, Front Cover: passo 3, imagem 2 %32
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
    Pergunte ao FixBot
    Comentar
  4. Nokia 1100b RH-36 Screen Replacement, Inner Casing: passo 4, imagem 1 %32 Nokia 1100b RH-36 Screen Replacement, Inner Casing: passo 4, imagem 2 %32
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
    Pergunte ao FixBot
    Comentar
  5. Nokia 1100b RH-36 Screen Replacement, Screen: passo 5, imagem 1 %32 Nokia 1100b RH-36 Screen Replacement, Screen: passo 5, imagem 2 %32
    • Flip over the metal frame you just removed.
    • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
    • Remove the screen bearing plastic frame.
    Pergunte ao FixBot
    Comentar
Conclusão
JSwan
Membro desde: 04/12/13
811 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 10-43, Amido Spring 2013 Membro de Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 2,435
