Ir para o conteúdo principal
Nokero SunRay Pro Power Panel Capacitor Replacement
O que você precisa
  1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: passo 1, imagem 1 %32
    • Turn over the device so that the back of the device is facing up.
    Pergunte ao FixBot
    Comentar
  2. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 2, imagem 1 %32 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 2, imagem 2 %32 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 2, imagem 3 %32
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
    Pergunte ao FixBot
    Comentar
  3. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 3, imagem 1 %32 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 3, imagem 2 %32
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    Pergunte ao FixBot
    Comentar
  4. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 4, imagem 1 %32 Nokero SunRay Pro Power Panel Capacitor Replacement: passo 4, imagem 2 %32
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
    Pergunte ao FixBot
    Comentar
  5. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: passo 5, imagem 1 %32
    • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
    Pergunte ao FixBot
    Comentar
  6. Nokero SunRay Pro Power Panel Capacitor Replacement: passo 6, imagem 1 %32
    • Pull the capacitor through the circuit board to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Nicholas Orr
Membro desde: 01/20/15
229 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-3, Blackwell Winter 2015 Membro de USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 31
Ao todo: 517
