Ir para o conteúdo principal
Nobis NB09 Battery Replacement
O que você precisa
    1. Nobis NB09 Battery Replacement, Battery: passo 1, imagem 1 %32
      • Before beginning this process, make sure the device is powered off.
      • Remove the screws holding the case together.
      Pergunte ao FixBot
      Comentar
    2. Nobis NB09 Battery Replacement: passo 2, imagem 1 %32 Nobis NB09 Battery Replacement: passo 2, imagem 2 %32 Nobis NB09 Battery Replacement: passo 2, imagem 3 %32
      • Use an opening tool to loosen and pry off the pink back plate.
      Pergunte ao FixBot
      Comentar
    3. Nobis NB09 Battery Replacement: passo 3, imagem 1 %32 Nobis NB09 Battery Replacement: passo 3, imagem 2 %32
      • Remove the black electronic tape covering the circuit board.
      Pergunte ao FixBot
      Comentar
    4. Nobis NB09 Battery Replacement: passo 4, imagem 1 %32
      • Use the soldering iron to remove the black and red wires from the circuit board.
      • The black wire is the ground and the red wire is the battery positive terminal.
      • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
      Pergunte ao FixBot
      Comentar
    5. Nobis NB09 Battery Replacement: passo 5, imagem 1 %32 Nobis NB09 Battery Replacement: passo 5, imagem 2 %32
      • Gently loosen the adhesive under the battery to avoid damaging it.
      • Use caution; the battery is soft and will bend very easily.
      • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
      • When reassembling, apply adhesive to the back of the new battery.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Membro de UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Membros
Autoria de 12 guias
1Comentário do guia
where can i buy a battery from
Frederick Shipman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 38
Ao todo: 3,422
