Introdução
You can use this guide to replace the malfunctioning or cracked screen of the Nobis NB07 tablet. To do so, you will need to completely disassemble the tablet, using soldering tools in the process.
O que você precisa
Look towards the topside of the tablet, where the power button is located.
Insert a plastic opening tool in the crack between the two parts of the case.
Move it gently back and forth to open the case.
Locate the microphone's cables in front of the cameras' ZIF connector.
3 outras pessoas executaram este guia.
Um comentário
I think that remove the microphone, speakers and cameras are unnecessary. I had change the digiter and don't remove anything just the screws and be careful with the speaker and unlock the digiter cable in the left upper side and that's the parts that I had removed then the parts that you need remove is the battery and the 3 screws and unlock all the cables and the parts attached to the screen and that's it....
