Introdução
To complete this guide, you will need to disassemble your tablet and use a soldering iron to replace the battery. The battery is removed first in most cases, even if you are trying to remove other components.
O que você precisa
Look towards the topside of the tablet, where the power button is located.
Insert a plastic opening tool in the crack between the two parts of the case.
Move it gently back and forth to open the case.
3 outras pessoas executaram este guia.
Um comentário
where do you find that battery? tried searching by the numbers on it and nothing
