Introdução
Use this guide to replace the disc drive in your Nintendo Wii mini.
Turn the Wii mini upside down.
Remove the two rubber feet at the back of the console to reveal the hidden screws.
Remove the four 6mm Phillips #0 screws.
Turn the Wii mini around so that the back of the device is facing you.
Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
Using your fingers, slide out the blue ribbon cable from the the top of the power board.
Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
Uma outra pessoa concluiu este guia.
