Ir para o conteúdo principal
Nintendo Wii Remote Sensor Screen Replacement
O que você precisa
  1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: passo 1, imagem 1 %32 Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: passo 1, imagem 2 %32
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Wii Remote Sensor Screen Replacement: passo 2, imagem 1 %32
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Wii Remote Sensor Screen Replacement: passo 3, imagem 1 %32
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Wii Remote Sensor Screen Replacement: passo 4, imagem 1 %32 Nintendo Wii Remote Sensor Screen Replacement: passo 4, imagem 2 %32
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: passo 5, imagem 1 %32 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: passo 5, imagem 2 %32 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: passo 5, imagem 3 %32
    • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
    • Grip the outward edge of the screen with your fingers.
    • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
    Pergunte ao FixBot
    Comentar
Conclusão
16 outras pessoas executaram este guia.
Emily
Membro desde: 04/14/13
2.015 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-44, Amido Spring 2013 Membro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Membros
Autoria de 29 guias
2Comentários do guia
Where can the screen be purchased??
cutsiepie6480 - Responder Compartilhar
how is this moderate difficulty
Sqwerks - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 101
Últimos 30 dias: 353
Ao todo: 27,681
