Ir para o conteúdo principal
Nintendo Wii Remote Motherboard Replacement
O que você precisa
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: passo 1, imagem 1 %32 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: passo 1, imagem 2 %32
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Wii Remote Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Wii Remote Motherboard Replacement: passo 3, imagem 1 %32
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Wii Remote Motherboard Replacement: passo 4, imagem 1 %32 Nintendo Wii Remote Motherboard Replacement: passo 4, imagem 2 %32
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Nintendo Wii Remote Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
    Pergunte ao FixBot
    Comentar
  6. Nintendo Wii Remote Motherboard Replacement: passo 6, imagem 1 %32 Nintendo Wii Remote Motherboard Replacement: passo 6, imagem 2 %32
    • Grasp the edges of the motherboard and pull it straight away from the case.
    Pergunte ao FixBot
    Comentar
Conclusão
36 outras pessoas executaram este guia.
Emily
Membro desde: 04/14/13
2.015 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-44, Amido Spring 2013 Membro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Membros
Autoria de 29 guias
7Comentários do guia
Where do you find a motherboard and how much do they typically cost?
Jeff - Responder Compartilhar
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Responder Compartilhar
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign - Responder Compartilhar
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Responder Compartilhar
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 70
Últimos 30 dias: 352
Ao todo: 40,523
