Ir para o conteúdo principal
Nintendo Wii Remote Main Buttons Replacement
O que você precisa
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: passo 1, imagem 1 %32 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: passo 1, imagem 2 %32
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Wii Remote Main Buttons Replacement: passo 2, imagem 1 %32
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Wii Remote Main Buttons Replacement: passo 3, imagem 1 %32
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Wii Remote Main Buttons Replacement: passo 4, imagem 1 %32 Nintendo Wii Remote Main Buttons Replacement: passo 4, imagem 2 %32
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: passo 5, imagem 1 %32 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: passo 5, imagem 2 %32
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
    Pergunte ao FixBot
    Comentar
  6. Nintendo Wii Remote Main Buttons Replacement: passo 6, imagem 1 %32
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
    Pergunte ao FixBot
    Comentar
Conclusão
27 outras pessoas executaram este guia.
Emily
Membro desde: 04/14/13
2.015 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-44, Amido Spring 2013 Membro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Membros
Autoria de 29 guias
5Comentários do guia
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - Responder Compartilhar
Me too, can’t find them.
Michael Velten - Responder Compartilhar
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - Responder Compartilhar
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - Responder Compartilhar
Yo tampoco los encuentro por ninguna parte
kinoto taller - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 86
Últimos 30 dias: 348
Ao todo: 49,459
