Introdução
This guide will show you the steps on installing the motherboard. This will be helpful if the controller won't turn on or if it turns on and doesn't work.
O que você precisa
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Using tweezers remove the three grey button pads from the motherboard.
6 outras pessoas executaram este guia.
