Ir para o conteúdo principal
Nintendo WaveBird Wireless Controller Channel Wheel Replacement
O que você precisa
  1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: passo 1, imagem 1 %32 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: passo 1, imagem 2 %32
    • Pull down on the battery cover release lever and pull back to remove the cover.
    Pergunte ao FixBot
    Comentar
  2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: passo 2, imagem 1 %32
    • Remove both batteries from the device.
    Pergunte ao FixBot
    Comentar
  3. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: passo 3, imagem 1 %32 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: passo 3, imagem 2 %32
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    Pergunte ao FixBot
    Comentar
  4. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: passo 4, imagem 1 %32 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: passo 4, imagem 2 %32
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    Pergunte ao FixBot
    Comentar
  5. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: passo 5, imagem 1 %32 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: passo 5, imagem 2 %32 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    Pergunte ao FixBot
    Comentar
  6. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Motherboard: passo 6, imagem 1 %32
    • Using tweezers remove the three grey button pads from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: passo 7, imagem 1 %32
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
    Pergunte ao FixBot
    Comentar
  8. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Channel Wheel: passo 8, imagem 1 %32
    • Turn the motherboard over so the channel wheel is facing up.
    Pergunte ao FixBot
    Comentar
  9. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: passo 9, imagem 1 %32 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: passo 9, imagem 2 %32
    • Pinch the wheel and pull it away from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 10-40, Amido Spring 2013 Membro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membros
Autoria de 38 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 42
Ao todo: 2,755
