Ir para o conteúdo principal
Nintendo Switch Right Joy-Con Buttons Replacement
O que você precisa
  1. Nintendo Switch Right Joy-Con Buttons Replacement, Right Joy-Con Buttons: passo 1, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement, Right Joy-Con Buttons: passo 1, imagem 2 %32 Nintendo Switch Right Joy-Con Buttons Replacement, Right Joy-Con Buttons: passo 1, imagem 3 %32
    • Use a Tri-wing Y00 screwdriver to remove the four 5mm screws holding the back panel in place.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Switch Right Joy-Con Buttons Replacement: passo 2, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 2, imagem 2 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 2, imagem 3 %32
    • Insert the end of a plastic opening pick between the IR sensor and the back panel.
    • Run the tool along the edge, gently applying pressure downwards, to release the back panel from the clips holding it in place.
    • Do not use any metal tools for this step as you will risk damaging the plastic clips holding the back panel in place.
    • Open the Joy-Con as if it was a book, rotating around the black guide rail.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Switch Right Joy-Con Buttons Replacement: passo 3, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 3, imagem 2 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 3, imagem 3 %32
    • Pull the Bluetooth antenna out of its compartment and out of the way of the battery.
    • Using a plastic opening tool, lift the battery up and out of its compartment from the right edge.
    • The battery is held in place by adhesive tape and may take a bit of force to remove.
    • Be careful not to pull the battery or antenna out completely as they are still connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Switch Right Joy-Con Buttons Replacement: passo 4, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 4, imagem 2 %32
    • Disconnect the battery by using a plastic spudger to gently apply pressure upwards to the base of the connector.
    • Repeat the same process with the Bluetooth antenna connector.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Switch Right Joy-Con Buttons Replacement: passo 5, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 5, imagem 2 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 5, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the three 2mm screws holding the battery compartment in place.
    • Lift and rotate the battery compartment away from the motherboard.
    • Be very cautious of the fragile ribbon cable that connects the compartment to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Nintendo Switch Right Joy-Con Buttons Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, gently lift the grey clasp holding down the ribbon cable and slide it out from its connector.
    Pergunte ao FixBot
    Comentar
  7. Nintendo Switch Right Joy-Con Buttons Replacement: passo 7, imagem 1 %32
    • Using tweezers, gently lift the black and white clasps holding the two ribbon cables.
    • Slide the two ribbon cables out from their connectors to release the back panel and guide rail assembly.
    Pergunte ao FixBot
    Comentar
  8. Nintendo Switch Right Joy-Con Buttons Replacement: passo 8, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 8, imagem 2 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 8, imagem 3 %32
    • Using tweezers, gently lift the black clasp holding the joystick ribbon cable in place.
    • Slide the ribbon cable out from its connector.
    • Using a Phillips #00 screwdriver, remove the two screws holding the joystick assembly in place.
    Pergunte ao FixBot
    Comentar
  9. Nintendo Switch Right Joy-Con Buttons Replacement: passo 9, imagem 1 %32
    • Gently lift the joystick up and out of its holder.
    Pergunte ao FixBot
    Comentar
  10. Nintendo Switch Right Joy-Con Buttons Replacement: passo 10, imagem 1 %32
    • Remove the right shoulder button from its holder.
    • Note that the button has a spring attached which will need to be fitted back into place when reinstalling.
    Pergunte ao FixBot
    Comentar
  11. Nintendo Switch Right Joy-Con Buttons Replacement: passo 11, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 11, imagem 2 %32
    • Using a spudger, gently pry upwards on both the left and right sides of the vibrator.
    • The vibrator is held in place with adhesive so it may take a bit of force to remove.
    • Once the vibrator is removed from its holder do not disconnect the cable. Instead, just move it to the side.
    Pergunte ao FixBot
    Comentar
  12. Nintendo Switch Right Joy-Con Buttons Replacement: passo 12, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 12, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the two 1.5 mm screws holding the motherboard in place.
    • Be careful as this is the only thing holding the buttons down and they will become loose once the screws are removed.
    Pergunte ao FixBot
    Comentar
  13. Nintendo Switch Right Joy-Con Buttons Replacement: passo 13, imagem 1 %32 Nintendo Switch Right Joy-Con Buttons Replacement: passo 13, imagem 2 %32
    • Carefully lift the motherboard up and away from the casing.
    • Be cautious of the two remaining ribbon cables. If you pull too hard you will risk damaging the cables.
    • Using tweezers, gently lift the clasps holding the ribbon cables in place.
    • Slide the ribbon cables out of their connectors to release the motherboard from the casing.
    Pergunte ao FixBot
    Comentar
  14. Nintendo Switch Right Joy-Con Buttons Replacement: passo 14, imagem 1 %32
    • Remove the rubber covers from the buttons.
    Pergunte ao FixBot
    Comentar
  15. Nintendo Switch Right Joy-Con Buttons Replacement: passo 15, imagem 1 %32
    • Using tweezers, lift the buttons out from their holders.
    • Note that the buttons have notches to ensure the right orientation when replacing. If you do not line up the notches properly the buttons may be unresponsive.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Be sure not to screw the motherboard in too tight as this may affect the responsiveness of the buttons. Always apply even pressure to screws when reinstalling the components; one side should not be tighter than the other.
48 outras pessoas executaram este guia.
Michael Lowden
Membro desde: 05/12/20
1.565 Reputação
Autoria de 1 guia
Equipe
10Comentários do guia
Thank you. The guide from the company I bought the replacement buttons from on Amazon was extremely lacking. This was on point.
Drew B - Responder Compartilhar
How do I take the black inner part of the home button out of it’s holding thing?
Martin Drkoš - Responder Compartilhar
I need help with this as well. In the last picture you can see how the home button sits in a clear plastic ring and I cant get it out of there to place my new colorful home button
Zachary Reeves - Responder Compartilhar
Doesn’t include how to change the trigger button…. :/
Harmony Petersen - Responder Compartilhar
Super guide as always. Succesfully replaced the sl and sr buttons. Thanks!!
Richard Kroon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 28
Últimos 7 dias: 210
Últimos 30 dias: 1,212
Ao todo: 102,475
