Ir para o conteúdo principal
Nintendo Switch Pro Controller Trigger Button Replacement
O que você precisa
  1. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: passo 1, imagem 1 %32
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    Pergunte ao FixBot
  2. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: passo 2, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: passo 2, imagem 2 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: passo 2, imagem 3 %32
    • Carefully remove the handle covers by pulling them away from the main body.
    Pergunte ao FixBot
  3. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: passo 3, imagem 1 %32
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
    Pergunte ao FixBot
  4. Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: passo 4, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: passo 4, imagem 2 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: passo 4, imagem 3 %32
    • Carefully pry away the clear plastic cover using your fingernail.
    Pergunte ao FixBot
  5. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the clear plastic cover: passo 5, imagem 1 %32
    • Remove the clear plastic cover.
    Pergunte ao FixBot
  6. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: passo 6, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: passo 6, imagem 2 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: passo 6, imagem 3 %32
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
    Pergunte ao FixBot
  7. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: passo 7, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: passo 7, imagem 2 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: passo 7, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
    Pergunte ao FixBot
  8. Nintendo Switch Pro Controller Trigger Button  Replacement: passo 8, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement: passo 8, imagem 2 %32 Nintendo Switch Pro Controller Trigger Button  Replacement: passo 8, imagem 3 %32
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    Pergunte ao FixBot
  9. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the flap: passo 9, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Open the flap: passo 9, imagem 2 %32
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    Pergunte ao FixBot
  10. Nintendo Switch Pro Controller Trigger Button  Replacement, Disconnect the interconnect cable: passo 10, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Disconnect the interconnect cable: passo 10, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    Pergunte ao FixBot
  11. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the front case: passo 11, imagem 1 %32
    • Remove the front case.
    Pergunte ao FixBot
  12. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: passo 12, imagem 1 %32
    • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
    Pergunte ao FixBot
  13. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the ZIF connector: passo 13, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement, Open the ZIF connector: passo 13, imagem 2 %32
    • Use a spudger to flip up the locking tab on the ZIF connector.
    Pergunte ao FixBot
  14. Nintendo Switch Pro Controller Trigger Button  Replacement: passo 14, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement: passo 14, imagem 2 %32
    • Remove the black ribbon cable from its connector.
    • Only a small amount of force should be needed to remove the ribbon cable.
    Pergunte ao FixBot
  15. Nintendo Switch Pro Controller Trigger Button  Replacement: passo 15, imagem 1 %32 Nintendo Switch Pro Controller Trigger Button  Replacement: passo 15, imagem 2 %32
    • Remove the trigger buttons from the plastic cover.
    Pergunte ao FixBot
Conclusão
16 outras pessoas executaram este guia.
Simon Lin
Membro desde: 10/10/19
434 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G2, Regan Fall 2019 Membro de Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Membros
Autoria de 45 guias
6Comentários do guia
This guide does show how to remove the trigger/bumper casing and board from the controller but does not show how to remove the triggers/bumpers from the casing they are in.
Boushi Adams - Responder Compartilhar
Yeah, this is a pretty big point to be missing, especially with the Flex Cable for the shoulder button inputs being right beside the post you need to pull out to remove the ZL and ZR buttons. Guidance on how to remove the post safely without damaging the cable would be great.
Alex Crocker - Responder Compartilhar
Used the guide to repair a shattered right shoulder button successfully. Thanks!
Christian - Responder Compartilhar
After reinstalling the shoulder buttons I have found them to stop working, all four, I checked my ribbon cable from the buttons to the board and even replaced it. I also confirmed the ribbon cable connector on the main board is working as well. Can anyone make any further troubleshooting suggestions?
David - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 76
Últimos 30 dias: 490
Ao todo: 57,783
