Ir para o conteúdo principal
Nintendo NES Advantage B Button Replacement
O que você precisa
  1. Nintendo NES Advantage B Button Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
    Pergunte ao FixBot
    Comentar
  2. Nintendo NES Advantage B Button Replacement: passo 2, imagem 1 %32 Nintendo NES Advantage B Button Replacement: passo 2, imagem 2 %32
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
    Pergunte ao FixBot
    Comentar
  3. Nintendo NES Advantage B Button Replacement, Circuit Board: passo 3, imagem 1 %32 Nintendo NES Advantage B Button Replacement, Circuit Board: passo 3, imagem 2 %32
    • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
    • Lift the gray component away from the device.
    Pergunte ao FixBot
    Comentar
  4. Nintendo NES Advantage B Button Replacement: passo 4, imagem 1 %32
    • Lift up the black wire and move it to the side.
    Pergunte ao FixBot
    Comentar
  5. Nintendo NES Advantage B Button Replacement: passo 5, imagem 1 %32 Nintendo NES Advantage B Button Replacement: passo 5, imagem 2 %32 Nintendo NES Advantage B Button Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the two silver knobs on the front of the device.
    • Unscrew the two silver nuts using a flathead screwdriver.
    • Remove each silver nut and silver washer using a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  6. Nintendo NES Advantage B Button Replacement: passo 6, imagem 1 %32 Nintendo NES Advantage B Button Replacement: passo 6, imagem 2 %32
    • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
    • Remove the silver bracket from the top of the circuit board.
    Pergunte ao FixBot
    Comentar
  7. Nintendo NES Advantage B Button Replacement: passo 7, imagem 1 %32
    • Remove the circuit board from the controller.
    Pergunte ao FixBot
    Comentar
  8. Nintendo NES Advantage B Button Replacement, B Button: passo 8, imagem 1 %32
    • Remove the B button from the case (or the circuit board if it got stuck).
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 457
