Introdução
If you are having problems with your Nintendo NES Advantage Model NES-026 A Button, you will need to remove it.
The A Button is used to send inputs to the device. You will need to remove the A Button if it is stuck in the pressed position or too stiff to move.
Before you start working on this guide, make sure the device is unplugged from any external sources.
O que você precisa
Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
Lift the gray component away from the device.
1Comentário do guia
You can use a 10 mm socket wrench for the silver nuts behind the gray knobs ( step 5)
