Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The battery is a rectangular unit with electrical information printed on one side. It is located on the back of the Game Boy Advance SP.
O que você precisa
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
For reassembly, follow the instructions in reverse order.
30 outras pessoas executaram este guia.
2 comentários
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
