Ir para o conteúdo principal
Nintendo Entertainment System Motherboard Replacement
O que você precisa
  1. Nintendo Entertainment System Motherboard Replacement, Game Cartridge Tray: passo 1, imagem 1 %32 Nintendo Entertainment System Motherboard Replacement, Game Cartridge Tray: passo 1, imagem 2 %32
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Entertainment System Motherboard Replacement: passo 2, imagem 1 %32 Nintendo Entertainment System Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Entertainment System Motherboard Replacement: passo 3, imagem 1 %32 Nintendo Entertainment System Motherboard Replacement: passo 3, imagem 2 %32 Nintendo Entertainment System Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Entertainment System Motherboard Replacement: passo 4, imagem 1 %32 Nintendo Entertainment System Motherboard Replacement: passo 4, imagem 2 %32
    • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
    • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Entertainment System Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Nintendo Entertainment System Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Nintendo Entertainment System Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Remove the three 13.25mm Phillips screws that secure the motherboard to the lower case with a Phillips head #2 screwdriver.
    • Pull the motherboard assembly straight up and out of the plastic case with your hands.
    • Turn the motherboard assembly over so the metal cover is facing you.
    Pergunte ao FixBot
    Comentar
  6. Nintendo Entertainment System Motherboard Replacement: passo 6, imagem 1 %32
    • Disconnect the wire harnesses from the motherboard assembly:
    • Controller 1 (left)
    • Controller 2 (right)
    • Power
    • To prevent mixing the wires up during reassembly, it can be helpful to label the wires with a piece of tape.
    Pergunte ao FixBot
    Comentar
  7. Nintendo Entertainment System Motherboard Replacement: passo 7, imagem 1 %32 Nintendo Entertainment System Motherboard Replacement: passo 7, imagem 2 %32 Nintendo Entertainment System Motherboard Replacement: passo 7, imagem 3 %32
    • Lift off the EMI shield (metal cover) from the motherboard assembly.
    • Turn over the motherboard assembly so the 72-PIN connector is on the top of the motherboard assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
32 outras pessoas executaram este guia.
nicholasweiser
Membro desde: 09/22/10
2.781 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-40, Forte Fall 2010 Membro de Cal Poly, Team 14-40, Forte Fall 2010
CPSU-FORTE-F10S14G40
4 Membros
Autoria de 28 guias
8Comentários do guia
What do I do if my console doesn't work at all I put a game in and the power light flashes on and off and or the screen stays on purple
Albert lopez - Responder Compartilhar
Clean the 72-pin connector and cartridge pins
Fritz Geib - Responder Compartilhar
What do I do if my console doesn't work at all the power light flashes on and off or it'll stay on but the screen shows purple what could be the
you need to change the cartridge connector (the one to the mainboard)
Brede Basualdo - Responder Compartilhar
Hello can you tell me why my nes turns on but I don’t get any sound or picture of the tv.
Jay - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 38
Últimos 30 dias: 178
Ao todo: 51,349
