Ir para o conteúdo principal
Nintendo DSi XL Power Board Replacement
O que você precisa
  1. Nintendo DSi XL Power Board Replacement, Battery: passo 1, imagem 1 %32 Nintendo DSi XL Power Board Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    Pergunte ao FixBot
    Comentar
  2. Nintendo DSi XL Power Board Replacement: passo 2, imagem 1 %32
    • Lift the battery from the DSi XL.
    Pergunte ao FixBot
    Comentar
  3. Nintendo DSi XL Power Board Replacement, Lower Case: passo 3, imagem 1 %32 Nintendo DSi XL Power Board Replacement, Lower Case: passo 3, imagem 2 %32 Nintendo DSi XL Power Board Replacement, Lower Case: passo 3, imagem 3 %32
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    Pergunte ao FixBot
    Comentar
  4. Nintendo DSi XL Power Board Replacement: passo 4, imagem 1 %32
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
    Pergunte ao FixBot
    Comentar
  5. Nintendo DSi XL Power Board Replacement: passo 5, imagem 1 %32 Nintendo DSi XL Power Board Replacement: passo 5, imagem 2 %32 Nintendo DSi XL Power Board Replacement: passo 5, imagem 3 %32
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    Pergunte ao FixBot
    Comentar
  6. Nintendo DSi XL Power Board Replacement: passo 6, imagem 1 %32 Nintendo DSi XL Power Board Replacement: passo 6, imagem 2 %32
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Nintendo DSi XL Power Board Replacement: passo 7, imagem 1 %32 Nintendo DSi XL Power Board Replacement: passo 7, imagem 2 %32
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    Pergunte ao FixBot
    Comentar
  8. Nintendo DSi XL Power Board Replacement, Power Board: passo 8, imagem 1 %32 Nintendo DSi XL Power Board Replacement, Power Board: passo 8, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Nintendo DSi XL Power Board Replacement: passo 9, imagem 1 %32
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
    Pergunte ao FixBot
    Comentar
  10. Nintendo DSi XL Power Board Replacement: passo 10, imagem 1 %32 Nintendo DSi XL Power Board Replacement: passo 10, imagem 2 %32
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Brett Hartt
Membro desde: 04/12/10
132.210 Reputação
Autoria de 144 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 27.484 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 149
Ao todo: 19,370
