Ir para o conteúdo principal
Nintendo DSi Motherboard Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Cuidado: os passos de 1 a 2 são provenientes de um guia marcado como em andamento.
    Nintendo DSi Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
    Pergunte ao FixBot
    Comentar
  2. Nintendo DSi Motherboard Replacement: passo 2, imagem 1 %32
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
    Pergunte ao FixBot
    Comentar
  3. Nintendo DSi Motherboard Replacement, Lower Case Assembly: passo 3, imagem 1 %32 Nintendo DSi Motherboard Replacement, Lower Case Assembly: passo 3, imagem 2 %32
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
    Pergunte ao FixBot
    Comentar
  4. Nintendo DSi Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
    Pergunte ao FixBot
    Comentar
  5. Nintendo DSi Motherboard Replacement: passo 5, imagem 1 %32 Nintendo DSi Motherboard Replacement: passo 5, imagem 2 %32 Nintendo DSi Motherboard Replacement: passo 5, imagem 3 %32
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
    Pergunte ao FixBot
    Comentar
  6. Nintendo DSi Motherboard Replacement: passo 6, imagem 1 %32 Nintendo DSi Motherboard Replacement: passo 6, imagem 2 %32
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
    Pergunte ao FixBot
    Comentar
  7. Nintendo DSi Motherboard Replacement, Wi-Fi Board: passo 7, imagem 1 %32
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
    Pergunte ao FixBot
    Comentar
  8. Nintendo DSi Motherboard Replacement: passo 8, imagem 1 %32
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
    Pergunte ao FixBot
    Comentar
  9. Nintendo DSi Motherboard Replacement, Battery Board: passo 9, imagem 1 %32
    • Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
    Pergunte ao FixBot
    Comentar
  10. Nintendo DSi Motherboard Replacement: passo 10, imagem 1 %32 Nintendo DSi Motherboard Replacement: passo 10, imagem 2 %32 Nintendo DSi Motherboard Replacement: passo 10, imagem 3 %32
    • The power connector (with red and black wires) is difficult to remove without damaging it, unless you take a moment and understand how it works. Look at all of the photos for this step before continuing.
    • The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
    • There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
    • If it does not lift easily, try again with a smaller screwdriver. You might be pulling the female connector off the board, which will be difficult to repair.
    Pergunte ao FixBot
    Comentar
  11. Nintendo DSi Motherboard Replacement, Disconnecting (Top) Nintendo DSi Motherboard cables: passo 11, imagem 1 %32 Nintendo DSi Motherboard Replacement, Disconnecting (Top) Nintendo DSi Motherboard cables: passo 11, imagem 2 %32
    • If you have not already done so, disconnect the two bottom-LCD ribbon cables from the main board by prying up the black latches and pulling the cable out to the side.
    • The ribbon cable (marked in blue) for the touch screen is particularly thin and fragile; be careful to avoid bending it more than necessary.
    • Flip up the latch and remove the touch screen cable.
    • Flip up the latch and remove the top-screen ribbon cable.
    • Pry up on the orange cable to disconnect it from the main board, much like the antenna cable on the Wi-Fi module.
    • Do not pull on the orange cable that connects to the bottom of the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Nintendo DSi Motherboard Replacement, Motherboard: passo 12, imagem 1 %32 Nintendo DSi Motherboard Replacement, Motherboard: passo 12, imagem 2 %32
    • Remove 4 Phillips screws from the board.
    • Lift the main board from the bottom end and flip it over to reveal the last connector.
    • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
    Pergunte ao FixBot
    Comentar
  13. Nintendo DSi Motherboard Replacement: passo 13, imagem 1 %32
    • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
    • The motherboard should now be free from the rest of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
rwong05
Membro desde: 11/04/09
214 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-1, Maness Fall 2009 Membro de Cal Poly, Team 6-1, Maness Fall 2009
CPSU-MANESS-F09S6G1
5 Membros
Autoria de 4 guias
1Comentário do guia
the screwdriver needed is not a phillips #00, but a phillips #0000. I went down to Sears with my DSi and the Craftsman #00 was too large, the Craftsman #0000 (item 41645) fit perfectly, and was only two bucks
gubment cheez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 55
Ao todo: 12,974
