Ir para o conteúdo principal
Nintendo DS Back Panel Replacement
O que você precisa
  1. Nintendo DS Back Panel Replacement, Battery: passo 1, imagem 1 %32 Nintendo DS Back Panel Replacement, Battery: passo 1, imagem 2 %32 Nintendo DS Back Panel Replacement, Battery: passo 1, imagem 3 %32
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Nintendo DS Back Panel Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
    Pergunte ao FixBot
    Comentar
  3. Nintendo DS Back Panel Replacement: passo 3, imagem 1 %32
    • Remove the battery from the Nintendo DS.
    Pergunte ao FixBot
    Comentar
  4. Nintendo DS Back Panel Replacement, Back Panel: passo 4, imagem 1 %32
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
    Pergunte ao FixBot
    Comentar
  5. Nintendo DS Back Panel Replacement: passo 5, imagem 1 %32 Nintendo DS Back Panel Replacement: passo 5, imagem 2 %32 Nintendo DS Back Panel Replacement: passo 5, imagem 3 %32
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
    Pergunte ao FixBot
    Comentar
Conclusão
20 outras pessoas executaram este guia.
dnguye26
Membro desde: 10/28/09
758 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-3, Maness Fall 2009 Membro de Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Membros
Autoria de 31 guias
2Comentários do guia
Where do I get a nintendo DS gamepak?
Kayla Maison - Responder Compartilhar
Kayla Maison , a gamepak is simply a GBA game.
Bob - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 73
Últimos 30 dias: 206
Ao todo: 21,413
