Ir para o conteúdo principal
Nintendo 3DS XL Microphone Replacement
O que você precisa
  1. Nintendo 3DS XL Microphone Replacement, Remove the back cover screws: passo 1, imagem 1 %32
    • Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
    • The screws have locking washers that prevent the screws from falling out. Keep these in place.
    Pergunte ao FixBot
    Comentar
  2. Nintendo 3DS XL Microphone Replacement, Remove the back cover: passo 2, imagem 1 %32 Nintendo 3DS XL Microphone Replacement, Remove the back cover: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
    • Use your hands to keep the clips from reattaching.
    • Use your hands to remove the back cover.
    Pergunte ao FixBot
    Comentar
  3. Nintendo 3DS XL Microphone Replacement: passo 3, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 3, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry the battery out of its recess and remove it.
    Pergunte ao FixBot
    Comentar
  4. Nintendo 3DS XL Microphone Replacement, Microphone: passo 4, imagem 1 %32 Nintendo 3DS XL Microphone Replacement, Microphone: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
    Pergunte ao FixBot
    Comentar
  5. Nintendo 3DS XL Microphone Replacement: passo 5, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 5, imagem 2 %32
    • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Nintendo 3DS XL Microphone Replacement: passo 6, imagem 1 %32
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Nintendo 3DS XL Microphone Replacement: passo 7, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 7, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 7, imagem 3 %32
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
    Pergunte ao FixBot
    Comentar
  8. Nintendo 3DS XL Microphone Replacement: passo 8, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 8, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 8, imagem 3 %32
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
    Pergunte ao FixBot
    Comentar
  9. Nintendo 3DS XL Microphone Replacement: passo 9, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 9, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 9, imagem 3 %32
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the microphone in the bottom left corner.
    • Using tweezers remove the microphone.
    • There will be a ribbon that connects the microphone to the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Nintendo 3DS XL Microphone Replacement: passo 10, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 10, imagem 2 %32
    • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
    • The attached microphone can now be removed.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Charlene Donlon
Membro desde: 04/08/14
11.225 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 9-13, Regan Spring 2014 Membro de Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 Membros
Autoria de 56 guias
2Comentários do guia
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - Responder Compartilhar
please learn to repair the mic of new 3ds xl
andrew.hws - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 34
Últimos 30 dias: 172
Ao todo: 15,736
