Ir para o conteúdo principal
Nintendo 3DS Wi-Fi Antenna Replacement
O que você precisa
  1. Nintendo 3DS Wi-Fi Antenna Replacement, Loosen the rear screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    #00 screwdriver is too big... probably need a #000
    thomascroguennec - Responder
    #00 will work - but you must press down firmly and sort of jerk the screw out a few degrees at a time. If you don't press firmly, the screws strip very easily. Using #000 will strip the screws more easily.
    Tai -
    I used a #0 without any issues and 0 stripped. I used the #0 for all screws internally and externally. The head was sharp and I applied adequate amounts of pressure when loosening the screw.
    Ben Kevan -
    The correct screwdriver should be a JIS, or you can get a screwdriver specific for the 3DS from other sites for less than $2
    Oscar - Responder
    do you have to buy it
    deeznuts -
    Where would I buy a screwdriver specifically for the 3DS? Also would it work on the DS? I need to replace the battery for my DS.
    Caitlin Lumsden -
    I used Phillips #000 and it worked like a charm, i need to order a new SD board or do you guys think i should send it. What happened is that it got water damaged and everything works fine when i opened it everything looked fine no signs of water corrosion everything on the 3DS works exept it always give me a message saying the SD card is locked and i know for a fact it isnt locked i already tried using 3 different SD cards and none of them are lock protected and yes they are formatted as well. I need help
    Leo Torres - Responder
    there's a switch on the SD card, switch it and it will be unlocked again. it happened to me once too.
    Bagel -
    david hodson you are incredible. literally all you need to do is heat the screen up and pry it off and you make them take apart the whole thing
    melody - Responder
    You've done this?
    magykmaster -
    I have to ask the same question. If just the glass display is broken, and you're heating it up to remove the glass, is it really necessary to remove everything? Doesn't like like it is necessary
    Wade -
    I just did it your way and it went fine. didnt even have to remove the battery. This is incredible misstep on the authors part.
    patrick -
    only take out the screen for a motherboard removal? Are you using the wrong guide or was this guide used for two different repairs?
    Reed Deemer -
    I used a PH0x50, but it wasn't easy.
    John - Responder
    This may be a dumb question but where do I buy the 3DS upper screen?
    John - Responder
    eBay... Just do a search for the 3DS Upper screen. $9.49 & it comes with the tools.
    Gary Darnell -
    The LCD screen I ordered came with all the tools I needed except a pair of tweezers. All in all it was about $14.00 and a little bit of my time.
    Gary Darnell - Responder
    Does anyone know where I can find the right bumper button for a 3ds? I can't find it on ebay must of damaged it playing smash bros.
    Steven Castro Parrilla - Responder
    Really wish I had read the comments first... How about instead of the warning saying to press down hardly and go slow, you say to use the correct screwdriver size like others mentioned in the comments. I not only stripped multiple screws, even after putting a glove on for more pressure, I bent my screwdriver from pressing down so hard. Granted it's a cheap jeweler's kit screwdriver, but it still would've been nice to not have that problem and be informed of the right size in the first place.
    hockeymorgan35 - Responder
    Got my tools one day after ordering, as I live a couple hours away from the supplier, Will post again when i try guide.
    nintendokakashi - Responder
    I tried doing this with a #00 Philips but it just didn't turn
    Acrobatic Mars01 - Responder
    Hello there, I need some assistance I have done a full housing replacement I have everything working except the 3d slider . The 3D option is always on can someone let me know which flex it is or what I am forgetting . Thanks guys !
    Noe Ibarra - Responder
    The 3D light lets you know there is a 3D option available for the current game you’re playing. Usually, it is always on, except when you’re playing a game that doesn’t support 3D. Turning the 3D slider off does not turn off the 3D LED.
    Scott D -
    I've always been lucky with these four, and at the time it was my first disassembly so I didn't know what stripping a screw was!
    FarmYard Gaming - Responder
    These screws don't strip easily, however, the screws at step 4 do.
    TheBlueInkling -
    It's JIS #00
    It's not the same thing
    Alstein Einbert - Responder
    To all the people that seem to think it's ok to tell people to use a phillips
    A PHILLIPS WILL damage the head of a JIS screw.
    The middle is thicker, which breaks the inner corners and the angle is less extreme causing it to slip out
    The extra pressure you add is to break that screw into a "phillips-ier" shape
    A newbie will still slip out and risk stipping the scew
    Btw you don't need to press hard with a JIS driver in a JIS screw
    If you don't know what you are doing, please refrain from editing this
    "All screws in this device are JIS screws. All official iFixit Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws."
    - dude who doesn't know anything
    Hi Alstein!
    You're right about most Phillips screwdrivers damaging JIS screws, but our Phillips bits (#000–1) are designed to be compatible with JIS of that size. We can't guarantee that Phillips drivers from other manufacturers are also cross compatible. We added the aforementioned bullet as a clarifier for this difference.
    Alex Diaz-Kokaisl -
    Hi Alex
    The bit still slips out easier due to the less extreme vertical angle, causing someone inexperienced to damage their screws.
    I and the Nintendo Homebrew community (talking about the hardware repair part of it) believe that even if it's true that the bit is shaped to cause less damage its completly wrong to tell someone to use the wrong bit as we get both people who ask "this bit is JIS friendly right" on normal phillips screwdrivers and people who come crying that they stripped their screws and have 0 idea why everyday so we know for a fact people are taking these kind of messages the wrong way.
    I believe the message i am putting is important as it tells the user the bits are different, tells them what to do if they don't have a JIS screwdriver and the damage its gonna cause.
    I'd agree to add a bullet that clarifies that ifixit phillips screwdrivers are designed to cause less damage under our disclaimer, not to just say phillips is fine to use on JIS
    Alstein Einbert -
    why is this guide telling you to use a Phillips screwdriver on a JIS
    this is just wrong
    "All screws in this device are JIS Screws, Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screw" wtf is this
    so you are saying that
    1. ifixit's phillips bit is a JIS because yes a JIS will work fine in a phillips screw, not vice versa.
    2. "use a ifixit phillips screwdriver that's the right screwdriver" instead of the jis one they might already have EVEN MAYBE FROM IFIXIT.
    yeah you mention in passing "or you could use a JIS Screwdriver but you should be mentioning in passing that ifixits phillips is ji-... ahem... i mean is compatible with jis screws
    this is absolutely stupid. Add that with the lack of care for looking for selling long lasting products like batteries and the lower quality of the recent bits i think ifixit is at its end.
    Daninator - Responder
    "i think ifixit is at its end." not in any way overdramatic at all
    FarmYard Gaming -
  2. Nintendo 3DS Wi-Fi Antenna Replacement, Remove the rear cover: passo 2, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Remove the rear cover: passo 2, imagem 2 %32
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
    Rember to transfer the model number sticker to the new cover
    Caleb Mezenberg (Caleb) - Responder
  3. Nintendo 3DS Wi-Fi Antenna Replacement, Battery: passo 3, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Battery: passo 3, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Battery: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Wi-Fi Antenna Replacement, Lower Case: passo 4, imagem 1 %32
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
    Had to give up at this point. Tried using the ifixit #00 phillips screwdriver to take out two screws and ended up stripping them.
    Demios - Responder
    Stuck at the same spot, those screws are in there really tight.
    John Pasula - Responder
    Ruined my screws because of incorrect head, thanks!
    3dsuser - Responder
    I had so much trouble with these screws, I gave up. Unfortunately, I can't accept failure so tried again. I figured out if you turn it right before you loosen it worked. Maybe it was just me, but I turned it right then kept pressure as I turned to loosen. I was surprised I hadn't stripped any screws out.
    Nicole Bauer - Responder
    Does anyone have any idea of how to remove these screws. I've pretty badly stripped the screws and I've gone to 20+ pages trying to figure this. I'm considering just prying the !@#$ thing.
    Vino - Responder
    use a dremil and make it a flat head
    Ralph Prowant -
    ruined my screws here too...what the !@#$ nintendo?
    trying to survive a nuclear meltdown inside the !@#$ thing
    Hamza Jarkas - Responder
    More like trying to subtly enforce planned obsolescence by not allowing you to make repairs to your device.
    Ullyssys -
    I used a #00 Philips 1/8" bit with no problem; however, the narrow diameter of the counter sunk hole can inhibit making secure contact with the screw head. You can be using the right bit (#00) but if the diameter of the bit shaft is too big you won't get proper contact.
    I found this to be an excellent guide. Thanks
    Dave W - Responder
    Unscrewed the nine 6.3 mm screws using the J000 bit from the iFixit 54 bit driver kit without much effort & without stripping the screw heads. Just gotta really position the bit correctly on the screw to have a proper fitting & not strip the screw heads.
    STZ9 - Responder
    The screws didn't strip but the philips screw driver did? @__@
    These are rough either way.
    John Zhou - Responder
    I used a "Whia 273 - PH000x40" screwdriver and held it firmly pushing the palm of my hand on the yellow end of the screwdriver and rocked the screw slightly (counter clockwise and clockwise) until it started to move. Then, without letting up on the pressure I carefully backed it out. The screwdriver is excellent because it is hardened (unlike some cheapo's out there) and the very tip is blunt not sharp. If the tip is too sharp, the point will bottom out in the screw and the sides that do all the work, won't be able to fully contact the inside of the screw. This screwdriver fits so well that the screws actually stick to it once they are removed. If the screwdriver moves AT ALL when you initially try it in the screw, STOP and find a better one. Also, start with the screws in the center, somehow they seem a little easier until you get the feel for it.
    Paul -
    Push down hard and turn counter-clockwise, or push down and rotate 3DS counter-clockwise until screw is loose.
    Jonathan - Responder
    Had the exact same problem, even tried the #000 screw driver too. Stripped the screws due to how tightly they are screwed in there and how easy they strip. I am now unsure what to do from here or if all I can do is give up.
    Sean Baldwin - Responder
    I second the one who suggested the Whia 273 PH000x40 screwdriver. I had a terrible time unscrewing these screws, and almost stripped them using a cheaper #000 screwdriver. Also tried a 3/16" flathead and destroyed the screwdriver. I bought the Whia and glad I did. It fit perfectly and did not slip at all. DEFINITELY recommend purchasing this high-quality screwdriver. Cost about $10 but well worth it to avoid the hassle.
    pbrazis - Responder
    The best way I found that works quite well, if you find a screwdriver or bit that is good enough: hold the screwdriver or bit with tons of pressure, and rotate the 3DS clockwise! It will come out in 5-6 rotations, you can do this step in about 10 minutes this way (put down a cloth first, don't scratch the front!)
    Gannon Trueman - Responder
    I HAVE A WAY TO GET OUT THE STRIPED SCREW. Like you, I had screwed up and tried everything to get the screw out. Do NOT try the glue in that tiny hole, you will get the screw glued permanently in there. The rubber band doesn't work in that tight space either. As desperate as I was, I was trying anything from nail polish to cramming the screw driver in as hard as I possible could. Until I realized that I had a drill. Yes, with the smallest head, I drilled into the screw a little bit, messed with the part I was trying to get out, drilled a little more, messed around, and then finally on my last attempt, I had successfully drilled off the top of the screw rendering the part free. It doesn't matter which drill you use as long as you can fit the head into the hole. Then drill forward like you are trying to drill a hole through wood. Now the only problem is that the remainder of the screw will be stuck in its place. All you really have to do is get a set of pliers and twist that puppy out. And there you go!
    YuuChan - Responder
    Most likely though, if you have all the other screws out and only have one striped screw, the part should just pop off and you wouldn't have to drill the entire head off the screw.
    YuuChan - Responder
    Got a brand new #00 screw drive and it striped the first time used it. So now I'm using eyeglass repair kit screw driver and it lasts longer that the one I got of of eBay.
    And I tried all of those tactics that people have been giving and none of them are working.
    The wiha 273 PH #000×40 unsrews it easily! It has a magnet on it!
    Najee - Responder
    I’m cant get these %#*@ screws out i want to die…
    FRØSTBIT3 - Responder
    Oh god, someone help i can’t get them out.
    Mark LaPierre - Responder
    omg everyone is struggling in here smh. I used my PH000 screwdriver made sure it went in aligned to the screws and applied pressure while turning counterclockwise. once it started the screw started lifting i stopped applying pressure and they lifted beautifully. saved damaging my screws with this technique. I also used the same screwdriver size to remove the orange screw where the game slot is. Yall are welcome lol
    Evelyn Avalos - Responder
    USE A DIFFERENT SCREWDRIVER.
    I was stuck on this for an hour. If your screwdriver is very thin, you won't get the grip necessary if your screws are on tight. I thought my screws were stripped but I switched to a bigger screwdriver and it was effortless. Just MAKE SURE IT IS A 00 PHILLIPS HEAD.
    brendon - Responder
    Use a JIS screwdriver, not Phillips! I bought the recommended screwdriver from this website and couldn't remove any screws. I went and purchased a J00 screwdriver and removed them quickly.
    danielle - Responder
    I used what I believe is a 1.5mm screwdriver which I received in one of those 60 in 1 precision screwdriver sets. It fit perfectly and much more snugly compared to any of the J0 - J000 bits.
    Andrew - Responder
    You should change the Screwdriver Type used. A Philipshead can damage Screws and/or Console. Use JIS Type-J00, which iFixIt sells, yes.
    J022 - Responder
    Lmao I've been using a Philips #00 for years and not known it was the wrong type. I ended up being fine here every time, a magnetic head helps. It's actually almost satisfying getting these ones out.
  5. Nintendo 3DS Wi-Fi Antenna Replacement: passo 5, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 5, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 5, imagem 3 %32
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
    When assembling, make sure that L ribbon is inside the case and R ribbon is not under the aluminium battery case. I got them both cut accidentally and had to replace :(
    Marek Jakóbiak - Responder
    Man muss die Folienkabel für die Tasten nicht unbedingt abziehen wenn man einen Gegenstand dahinter stellt, an dem man den Deckel senkrecht anlehnen kann.
    Jean - Responder
    Don't listen to the german guy. It's very easy to pop back
    Bruno N - Responder
  6. Nintendo 3DS Wi-Fi Antenna Replacement, Circle Pad Joystick: passo 6, imagem 1 %32
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
    my screws wont stop spining what to i do? i have the same problem with other screws and this leavs my joystick very loss and it is dificult to muve it becuase it is aganst the case not lifted up? any sugestions? (sorry for my bad speling jaja im very bad at speling..)
    AppleTopic - Responder
    I think you stripped your screws. I think the best solution is to change the upper cover of the lower assembly and the screws. The fastest, but temporarily is to stick in some way the joystick housing to the cover, but it won’t last long, so do this only if you have to use your console while you wait the cover to come. Anyway, so not overtighten the new screws, or you will be in the same situation once again.
    Daniele Carminati -
  7. Nintendo 3DS Wi-Fi Antenna Replacement: passo 7, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 7, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 7, imagem 3 %32
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
    When reassembling verify that the circle pad control is oriented right. I had to go back in after completion when I realized it wasn't centered.
    Daniel Johnson - Responder
    I would not disable the back side all the way because it could really mess up your 3DS.
    masterspeggy3 - Responder
    From this step, follow this video https://youtu.be/XGdRim2Mvrk?t=627
    you can skipp from step 8 to 20
    lots of unnecessary steps
    Bruno N - Responder
  8. Nintendo 3DS Wi-Fi Antenna Replacement: passo 8, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 8, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 8, imagem 3 %32
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
    Can you replace a zif socket? The little metal pieces on mine broke off...
    Colton Alverson - Responder
    YOUR &&^&@@ HAHAHAAHA, no you cant you would have to purchase a new motherboard i feek you bro happened in my first time
    vrobinson -
    you might want to find someone who is skilled in component level microsoldering for that
    Samuel Martin -
    The retaining flap on mine broke off, is there any way to fix it?
    Madi Hansen - Responder
    Don't do this step! it is not necessary. you can skip steps 8 through 20
    S Maduras - Responder
    Skip steps 8 through 20. It will save a lot of time. Thanks S Maduras for the warning.
    clarissa.vetintegral - Responder
    Thanks S Maduras! Your tip
    made this super easy. No need for steps 8-20.
    Carl Vero -
    OH MY GOD THANK YOU SO MUCH!!!! I'm sure I would have destroyed my ds if I did all that
    Amber Selley -
    Just like everyone else I recommend skipping to step 21. You don't need to take all the components out to replace the circle pad.
    Callum M. - Responder
    Skip steps 8-20 like they said!! Doing all those unnecessary steps wasted so so much time and frustrated me hugely by causing me to damage my microphone ribbon cable…
    Falcon - Responder
    What do you mean by skipping 8-20? Do I not need to remove the screws in order to replace the lower LCD?
    Marion Saga -
    you know, after you disconnect the ribbon from the mobo, you can just remove the back discs and the rubber part. no need to go past here.
    TruGoose - Responder
  9. Nintendo 3DS Wi-Fi Antenna Replacement: passo 9, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 9, imagem 2 %32
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
    When reassembling, you can use the pointy end of the spudger to align the hold again with the joystick. It’ll probably have bounced around while you’re moving other things.
    anthonyhersey - Responder
    If your only goal is to replace the circle-pad, the following steps are unnecessary. You can skip to step 21, the removal of the circle-pad.
    Andrew - Responder
  10. Nintendo 3DS Wi-Fi Antenna Replacement, SD Board: passo 10, imagem 1 %32
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  11. Nintendo 3DS Wi-Fi Antenna Replacement: passo 11, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 11, imagem 2 %32
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  12. Nintendo 3DS Wi-Fi Antenna Replacement: passo 12, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 12, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 12, imagem 3 %32
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
    be careful on this step, the sd card board is adhered to the rf shield below it, and bay result in the shield becoming bent as it is only soldered on one side. pry from the side of the board facing the cartridge slot.
    alex chargeer - Responder
    I didnt notice that and I broke the solders here :(
    Tony Greco -
    mine came off will this make the system not power on or make somthing not work? what do i do know?
    What did come off? the sd card reader board, or the shield mentioned in the above comment?
    Daniele Carminati -
    When putting it all back together, its easier to put the ribbon connector on before laying on the SD board.
    Pepper - Responder
    The adhesive sticker between the RF shield and the SD slot got mauled quite badly as I separated them, will this turn out to be a problem later?
    Nico - Responder
  13. Nintendo 3DS Wi-Fi Antenna Replacement, Pry the Wi-Fi card up: passo 13, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Pry the Wi-Fi card up: passo 13, imagem 2 %32
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  14. Nintendo 3DS Wi-Fi Antenna Replacement, Disconnect the Wi-Fi board: passo 14, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Disconnect the Wi-Fi board: passo 14, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Disconnect the Wi-Fi board: passo 14, imagem 3 %32
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
    That moment you bought all your supplies and realise while removing the wifi chip the antenna is not plugged in because you forgot to plug it in last time……… Scew me…
    Sidney the wolf - Responder
  15. Nintendo 3DS Wi-Fi Antenna Replacement, Motherboard Assembly: passo 15, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Motherboard Assembly: passo 15, imagem 2 %32
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  16. Nintendo 3DS Wi-Fi Antenna Replacement: passo 16, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 16, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 16, imagem 3 %32
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
    Can there be a guide on how to replace this part? I pry on the socket accidentally.
    im just a Ordinary marker - Responder
    I don't even know where they sell a new socket for this, but you'd need to have a soldering station and know how to micro solder. assuming no pads where ripped off then you'd just solder it back down. if a pad broke then you'd need to run jumpers to fix it. in short its very difficult and expensive to fix unless you have the know how and the tools already.
    ssanchez7610 -
  17. Nintendo 3DS Wi-Fi Antenna Replacement: passo 17, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 17, imagem 2 %32
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
    Be sure to fit the motherboard inbetween the joystick and volume slider in properly (you can double check by seeing if the volume slider on the outside goes up and down smoothly). When I closed it the first time it was stuck on full volume so I needed to go back in and readjust!
    Veronika Todd - Responder
    When putting the cable back I recommend to open the 3ds while keeping it face down so the cable has more room to fit.
    Roberto Cantu - Responder
    Thank you so much, opening the 3ds is needed to fit the cable back easily.
    Halefall -
    The camera ribbon cable contacts face towards the motherboard, the speaker ones face away.
    Nyuku - Responder
  18. Nintendo 3DS Wi-Fi Antenna Replacement: passo 18, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 18, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 18, imagem 3 %32
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
    Do yourself a favor and DON'T remove the 2.5 mm silver screw (yellow circle). It just holds in a little plastic bit under the volume control. The board comes out just fine with the screw still in. If you remove it, the plastic bit will fall out at random when you turn over the case.
    First time I took mine apart, I noticed something fall out later, tracked it down and then puzzled over what it was and where it came from.
    Chupi - Responder
    There is some adhesive where the AC adapter plugs in so I recommend watching out for that
    Devin Stephenson - Responder
    LISTEN TO CHUPI seriously that is such a pain to get back in
    NyxNullify - Responder
  19. Nintendo 3DS Wi-Fi Antenna Replacement: passo 19, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 19, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 19, imagem 3 %32
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
    Reinserting this ribbon cable is quite difficult. I found opening the case so that it sits upright at a 90 degree angle helps. The first two times I tried reassembling the top display did not work. Turned out that I was not inserting the ribbon cable in enough. I used tweezers to push this in by gently grabbing the ribbon cable. I was continually inspecting the cable for damage but apparently did not damage it. If anyone has a better idea on how to reinsert this cable I think others would greatly appreciate it.
    pbrazis - Responder
    Putting the cable back in is the hardest part out of all of this (if you can get past the screws near the beginning). If you have a friend that you trust very much and is very gentle, another pair of hands here really will help. If you're without a friend, make sure to use some flat, angled precision tweezers to push the ribbon in with one hand (pointed tweezers will do in a pinch but you'll have to be careful - I put a small dent in the ribbon and thought I'd broke it), and then use a spudge or something in the other to push the flap down.
    Also worth noting is that the ribbon for the top screen also handles the 3D - if you complete the guide and find you are unable to turn the 3D effect off, you didn't insert the ribbon enough, as I had the problem and re-inserting the ribbon fully fixed it.
    malcolmdemaggio - Responder
    Careful when reassembling -- watch the position of the black wifi antenna wire! I got mine most of the way back together and noticed it wouldn't close all the way. This wire had come out of the little posts holding it in place and was wedged between the screen and motherboard. Now I have to take it all apart again to fix this.
    Also if you're taking the board out of a working unit to get at the CLK signal to backup the NAND chip ("hardmod"), you don't need to remove the difficult ribbon cable in this step, or the other two wide ones at the top right from earlier. Leave them attached and swing the board out. It won't rotate a full 180 degrees to sit flat outside the unit, but you can open the screen 90 degrees to prop the rest up while having the board out on your table.
    Chupi - Responder
    I recommend not taking it off in the first place, as reattaching it is awfully difficult. You can easily clean out your abxy buttons with it still attached
    Martin - Responder
    I am having problems re-inserting the three ribbon cables (3DS XL). Do you need to flip up the retaining flaps first? (I just pulled them out of the slots when removing them.
    darren.brundell - Responder
    if the flap for the ribbon cable breaks what do you do
    lionmine ____ - Responder
    who else felt really proud after finally reinserting the cable
    Harrison Rigg - Responder
    The easiest way to get that ribbon back in is to hold it with some reverse tweezers that I fix it sells and use it to grab the ribbon and hold it while you fiddle with getting the ribbon in the slot. It’s super easy this way. You’ll have it installed in 36 seconds. Try it. (Reverse tweezers…press to release ones)
    Chris - Responder
  20. Nintendo 3DS Wi-Fi Antenna Replacement: passo 20, imagem 1 %32
    • Remove the motherboard assembly from the rest of the device.
    Make sure when putting the motherboard back onto the bottom part of the casing that the antenna wire is where it should be - the first time I put this back together the wire got loose and was smooshed in between the casing and the Y and Power buttons, causing them to be stiff/not work. Using the spudge should help in pushing the wire back into the slots along the inside of the case.
    when reassembling, watch out for the wireless on/off slider - i had started screwing things back in when i realized the slider had slipped to the wrong side, making the slider non functional. by the same token, watch out for the volume slider on the other side.
    meatshaped - Responder
  21. Nintendo 3DS Wi-Fi Antenna Replacement, Upper Display Front Panel: passo 21, imagem 1 %32
    • Before continuing with disassembly, use a pair of tweezers to remove the clear plastic diffuser for the wireless notification LED. The small piece is likely to fall out on its own, and may be difficult to find if it lands on the floor.
  22. Nintendo 3DS Wi-Fi Antenna Replacement: passo 22, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 22, imagem 2 %32
    • De-route the Wi-Fi antenna cable from the bottom of the upper case.
    • This step is not necessary if you are only replacing the front panel; however, the replacement of the upper screen, speakers, cameras, and Wi-Fi antenna require it.
  23. Nintendo 3DS Wi-Fi Antenna Replacement: passo 23, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 23, imagem 2 %32
    • Heat the edges of the upper display front panel with a hair dryer or heat gun to soften the adhesive holding it to the display bezel.
    • Begin prying the edges of the front panel off with a plastic opening tool.
    • If it is difficult to pry the front panel off, reheat the area you are working on with the heat gun, and then return to prying. Applying excessive force could crack the front panel.
    Maybe a dumb question, but how would I go about reattaching the top screen if it's attached to the 3ds by an adhesive? If I have to use more adhesive to put it back on, what would be the recommended kind to do so?
    jgonsoski - Responder
    I have the same question/concern that "jgonsoski" has. Is the adhesive on the front panel still usable after it's pried off the display bezel? Or does it have to be removed? If so, what adhesive can be used or is suitable to adhere back the front panel to the display bezel?
    STZ9 - Responder
    adhesive is definitely reusable. I just completed this step. Please make sure the new display is ready to take the tape as soon as you remove it from the old display.
    Xpider - Responder
    Disclaimer: I replaced my front panel entirely, and threw away the old one.
    If you do not have a replacement front panel, gently removing it (without getting the adhesive oily from your fingers/dusty) and replacing it is an option. The adhesive is incredibly tacky, and while removing the front panel will weaken the adhesive - it will likely be sticky enough to do its job. If not, double-sided tape or small amounts of water based craft glue may help (disclaimer again: I haven't tried these)- do NOT use superglues/liquid cements/epoxies.
    Tai -
  24. Nintendo 3DS Wi-Fi Antenna Replacement: passo 24, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 24, imagem 2 %32
    • Continue prying the remaining sides of the front panel by sliding the plastic opening tool down each edge.
    • Too little heat will result in excessive bending/breaking of the front panel, and too much will melt and destroy the LCD underneath. Take your time.
    BE VERY CAREFUL NOT TO MELT THE SPEAKERS. This happened to me and now one of the plastic covers for the speakers is melted inside the speaker itself, despite the display cover being undamaged. It is made of a much thinner plastic and i assume it heats up faster.
    Kishin Slayer - Responder
  25. Nintendo 3DS Wi-Fi Antenna Replacement: passo 25, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 25, imagem 2 %32
    • With all of the sides free, lift the upper display front panel off the display bezel.
  26. Nintendo 3DS Wi-Fi Antenna Replacement, Rear Display Bezel: passo 26, imagem 1 %32
    • Remove the six 3.6 mm Phillips screws securing the rear display bezel to the front display bezel.
    Some versions have a seventh screw under the right speaker, I almost broke mine because of that
    AD RC - Responder
  27. Nintendo 3DS Wi-Fi Antenna Replacement: passo 27, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 27, imagem 2 %32
    • Flip the device over so that the rear display bezel is on top and the hinge is on the side opposite from you.
    • Lift the edge of the rear display bezel closest to you and rotate it towards the hinge.
    • Continue to lift the rear display bezel off the rest of the device until it is free.
    • There are clips toward the bottom of the rear display bezel holding it in place. Use enough force to disengage the clips, but be careful not to break them.
  28. Nintendo 3DS Wi-Fi Antenna Replacement, Upper Display Assembly: passo 28, imagem 1 %32
    • Remove the 3D adjustment switch from the front display bezel.
    • This step is not necessary for disassembly, but the switch is likely to fall out on its own. By removing it yourself, you reduce the chance of losing it.
    What if I need a new one
    cbryans - Responder
  29. Nintendo 3DS Wi-Fi Antenna Replacement: passo 29, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 29, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 29, imagem 3 %32
    • Insert a metal probe into the space above the ABXY buttons with the point touching the metal hinge.
    • Push the hinge towards the center of the upper case. This will require a fair amount of force.
    • Before and after images of the hinge location when looking at the back of the upper display are shown.
    When reassembling you may find it difficult to get the bar back into the hole in the hinge. A couple of tips:
    * Reassemble it with the clamshell pieces in a ‘closed’ position (same position that you took it apart).
    * The pin/bar may have rotated slightly during disassembly (mine did). It only goes into the hole one way - the hole is actually a slot. If the alignment is off even a couple of degrees it won’t pop back in. If this happens simply lift the edge with the bar up out of the hinge and push the bar so it pops back out (like it was going into the hinge). The take a pair of pliers and gently rotate the bar to fix the alignment, pop the bar back to the ‘unhinged/open’ position, then reassemble.
    Bob Pony - Responder
  30. Nintendo 3DS Wi-Fi Antenna Replacement: passo 30, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 30, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 30, imagem 3 %32
    • Before proceeding, note how the 3 ribbon cables are oriented (what direction the gold contacts face) and layered together (which cable is on top of which). The cables are too short to reach if they are threaded through in any other orientation.
    • Slowly pull the upper display assembly away from the upper case.
    • Make sure that the various ribbon cables are being fed through the slit in the upper case.
    • Separate the upper display assembly from the upper case.
  31. Nintendo 3DS Wi-Fi Antenna Replacement, Speaker Assembly: passo 31, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Speaker Assembly: passo 31, imagem 2 %32
    • Carefully feed the speaker assembly ribbon cable through the hole in the upper display bezel.
    • You must gently coil the ribbon cables (similar to an ice-cream cone) to allow them to fit - the cables are wider than the hole.
    You may want to use small pieces of scotch tape to reinforce each individual ribbon cable before proceeding, being careful not to cover the gold contacts. The cables can be very brittle and when rolled up tightly they can crack and break like a dry leaf. The tape can be left on the cables after removal and installation.
    Benjificus - Responder
  32. Nintendo 3DS Wi-Fi Antenna Replacement: passo 32, imagem 1 %32
    • Remove the 2.5 mm Phillips screw securing the right speaker board to the upper display bezel.
  33. Nintendo 3DS Wi-Fi Antenna Replacement: passo 33, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 33, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 33, imagem 3 %32
    • Use the flat end of a spudger or your fingernail to flip up the retaining flaps on the parallax barrier ribbon cable ZIF sockets.
    • Use a pair of metal tweezers to disconnect the two ribbon cables.
    does it matter if these cables are not connected?
    nuggets321 - Responder
  34. Nintendo 3DS Wi-Fi Antenna Replacement: passo 34, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 34, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 34, imagem 3 %32
    • Use the flat end of a spudger to pry the left and right speakers out of their places in the upper display bezel.
    • Pry the camera status LED out of the upper display bezel with the tip of a spudger.
    I accidentally broke the ribbon cable for the camera status LED, reckon I'll get away with it being broken or will it need replacing?
    Dean Withington - Responder
  35. Nintendo 3DS Wi-Fi Antenna Replacement: passo 35, imagem 1 %32
    • Remove the speaker assembly from the rest of the display assembly.
    Das Flexkabel des Lautsprechers muss nicht entfernt werden. Das macht die Montage hinterher nur schwieriger
    Hardver Doki - Responder
  36. Nintendo 3DS Wi-Fi Antenna Replacement, Cameras: passo 36, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Cameras: passo 36, imagem 2 %32
    • Gently roll the upper LCD ribbon cable and camera ribbon cable together and insert them into the hinge opening.
    Whoever designed this is a major ****. I eventually found a tear on the new LCD's ribbon upon installing, and I recall having a really hard time twisting the 3 ribbons together and into that tiny hole.
    amat2424 - Responder
    This is the crazy hard part of the process. Be patient and it should eventually work. I found that reassembling but leaving all of the pieces out of the case (screen, camera harness, speaker harness) helped. It’s nearly impossible to do this if the screen is sitting in it’s normal position - the corner of the screen blocks a part of the hole. Assemble it all outside of the case, curl up the harnesses, and then work them through the hole. Once you have that done, then snake the wifi antenna through the hole. And finally place the screen into place (and the speakers/cameras/led). This probably took me an hour to figure out.
    Oh, and once all of that was done *then* I worried about curling things up again and getting that black bushing over the cables. I doubt I could have done it with the bushing in place in the hole.
    I’d recommend watching Daniel-Jay Pascual’s video and giving their method a shot. It did take awhile to get it just right, but I eventually got it to work. It worked best for me when I started twisting right below the contacts. As long as you are patient and don’t rush anything you’ll be fine.
    Michael - Responder
    When I was assembling back, when the time arrived of putting back the ribbon cables, I realized the cables need to be at specific order, otherwise they'll get tangled and will slowly slip away from the connection. I had to redo the entire process and weren't told about it until it was too late.
    Jose Ybarra (EbolaGW) - Responder
  37. Nintendo 3DS Wi-Fi Antenna Replacement: passo 37, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 37, imagem 2 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 37, imagem 3 %32
    • Use a pair of metal tweezers to remove the black metal hinge ring from the upper display bezel.
    • Carefully pull the camera and upper LCD ribbon cables through their hole in the upper display bezel.
    if you dont remove the ring and pull you will rip the camera
    Tyler Moffitt - Responder
  38. Nintendo 3DS Wi-Fi Antenna Replacement: passo 38, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement: passo 38, imagem 2 %32
    • Peel the camera ribbon cable off the back of the upper LCD.
    • The ribbon cable is held to the back of the LCD housing by an adhesive, so pull on it gently to avoid tearing the ribbon cable.
    • Remove the camera ribbon cable assembly.
  39. Nintendo 3DS Wi-Fi Antenna Replacement, Upper LCD: passo 39, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Upper LCD: passo 39, imagem 2 %32
    • Use your thumbs to push the upper LCD from the front out of the upper display bezel.
    • Remove the upper LCD.
  40. Nintendo 3DS Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 40, imagem 1 %32 Nintendo 3DS Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 40, imagem 2 %32
    • Pull the Wi-Fi antenna cable through its hole in the upper display bezel.
    • De-route the Wi-Fi antenna cable from the upper display bezel.
  41. Nintendo 3DS Wi-Fi Antenna Replacement: passo 41, imagem 1 %32
    • Remove the Wi-Fi antenna from the upper display bezel.
Conclusão
5 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
152.626 Reputação
Autoria de 127 guias
2 comentários
this guide is idiotic, i followed it to the letter and all it did was make me realize that there is a much easier and much safer way of replacing the antenna; steps 1-29 (step 30 if you want to, not necessary though) are fine and right on the money, however pushing the ribbons through makes it way more difficult when you could just remove the antenna board, thred just the wire through leaving the ribbons unchanched, and put in the replacement board and thread the wire through, then reassemble the console. this method almost guarantees that the ribbons wont get scratch and you wont get frustrated.
Andrew Clayton - Responder
this is amazing i will going to follow all steps it seems very difficult before i read this but now this will really helpful and easier than i thought thank you!! Antenna Amplifier
Rachel Gelller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 45
Últimos 30 dias: 135
Duração total: 18,555
