Ir para o conteúdo principal
Nintendo 3DS SD Board Replacement
O que você precisa
  1. Nintendo 3DS SD Board Replacement, Loosen the rear screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS SD Board Replacement, Remove the rear cover: passo 2, imagem 1 %32 Nintendo 3DS SD Board Replacement, Remove the rear cover: passo 2, imagem 2 %32
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS SD Board Replacement, Battery: passo 3, imagem 1 %32 Nintendo 3DS SD Board Replacement, Battery: passo 3, imagem 2 %32 Nintendo 3DS SD Board Replacement, Battery: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS SD Board Replacement, Lower Case: passo 4, imagem 1 %32
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
  5. Nintendo 3DS SD Board Replacement: passo 5, imagem 1 %32 Nintendo 3DS SD Board Replacement: passo 5, imagem 2 %32 Nintendo 3DS SD Board Replacement: passo 5, imagem 3 %32
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS SD Board Replacement, SD Board: passo 6, imagem 1 %32
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  7. Nintendo 3DS SD Board Replacement: passo 7, imagem 1 %32 Nintendo 3DS SD Board Replacement: passo 7, imagem 2 %32
    • The connector for the SD board sits underneath the Circle Pad ribbon cable.
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  8. Nintendo 3DS SD Board Replacement: passo 8, imagem 1 %32 Nintendo 3DS SD Board Replacement: passo 8, imagem 2 %32 Nintendo 3DS SD Board Replacement: passo 8, imagem 3 %32
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
Conclusão
22 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
154.580 Reputação
Autoria de 127 guias
12Comentários do guia
Where can i purchase the sd card board replacement part? Does amazon carry them?
Jen - Responder
You can usually find them on ebay to around $3 to $6 dollars (non oem and oem)
David Vokas -
Is there a way to do this with the older 3ds xl version? I didn't see any screws holding the sd board in when I opened it up.
NickySeley - Responder
Would this work for my problem? My problem is that the SD Card won't stay in, it just pops back out. Would this method still work? I'm not that experienced or knowledgeable about fixing these sort of things, so I'm not sure if the spring is part of it or not, lol. Also, where could I buy an SD Card board replacement part for cheap in Canada?
Caitlin Lumsden - Responder
Usually that is the locking mechanism, you can replace the SD card slot for around $6 or $3 if you buy the non oem part.
David Vokas -
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 103
Últimos 30 dias: 532
Ao todo: 34,010
