Introdução
Remove your broken Nintendo 3DS lower case and replace it with a fresh one.
O que você precisa
Ferramenta utilizada neste passo:Phillips #00 Screwdriver$5.49
Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
Pull the back cover up and away from the rest of the device to remove it.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
7 outras pessoas executaram este guia.
3 comentários
Is this guide for the original 3ds?
yessir it is
havent tried it (was thinking of shell swapping to see how hard it is) but it seems kinda easy for moderate rating you just remove 14 screws sorry if im wrong
