Ir para o conteúdo principal
Nintendo 3DS Circle Pad Joystick Replacement
O que você precisa
  1. Nintendo 3DS Circle Pad Joystick Replacement, Loosen the rear screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Circle Pad Joystick Replacement, Remove the rear cover: passo 2, imagem 1 %32 Nintendo 3DS Circle Pad Joystick Replacement, Remove the rear cover: passo 2, imagem 2 %32
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Circle Pad Joystick Replacement, Battery: passo 3, imagem 1 %32 Nintendo 3DS Circle Pad Joystick Replacement, Battery: passo 3, imagem 2 %32 Nintendo 3DS Circle Pad Joystick Replacement, Battery: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Circle Pad Joystick Replacement, Lower Case: passo 4, imagem 1 %32
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
  5. Nintendo 3DS Circle Pad Joystick Replacement: passo 5, imagem 1 %32 Nintendo 3DS Circle Pad Joystick Replacement: passo 5, imagem 2 %32 Nintendo 3DS Circle Pad Joystick Replacement: passo 5, imagem 3 %32
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS Circle Pad Joystick Replacement, Circle Pad Joystick: passo 6, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 7.7 mm screws securing the back of the Circle Pad to the motherboard.
  7. Nintendo 3DS Circle Pad Joystick Replacement: passo 7, imagem 1 %32 Nintendo 3DS Circle Pad Joystick Replacement: passo 7, imagem 2 %32 Nintendo 3DS Circle Pad Joystick Replacement: passo 7, imagem 3 %32
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  8. Nintendo 3DS Circle Pad Joystick Replacement: passo 8, imagem 1 %32 Nintendo 3DS Circle Pad Joystick Replacement: passo 8, imagem 2 %32 Nintendo 3DS Circle Pad Joystick Replacement: passo 8, imagem 3 %32
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
Conclusão
15 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
154.622 Reputação
Autoria de 127 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 94
Últimos 30 dias: 580
Ao todo: 40,646
