Ir para o conteúdo principal
Nintendo 3DS Back Cover Replacement
O que você precisa
  1. Nintendo 3DS Back Cover Replacement, Loosen the rear screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Back Cover Replacement, Remove the rear cover: passo 2, imagem 1 %32 Nintendo 3DS Back Cover Replacement, Remove the rear cover: passo 2, imagem 2 %32
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
Conclusão
19 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
154.668 Reputação
Autoria de 127 guias
3Comentários do guia
Anybody know where to buy replacement back covers for this original 3DS model? I’m finding that a lot of used 3DS’s from this era have 3rd party battery packs and the original cover is lost.
CORED3SIGN - Responder
Screws stripped what to do?
Joel - Responder
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 99
Últimos 30 dias: 577
Ao todo: 35,358
