Ir para o conteúdo principal
Nintendo 3DS 2015 C-Stick Replacement
O que você precisa
  1. Nintendo 3DS 2015 C-Stick Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
    Pergunte ao FixBot
    Comentar
  2. Nintendo 3DS 2015 C-Stick Replacement: passo 2, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 2, imagem 2 %32
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
    Pergunte ao FixBot
    Comentar
  3. Nintendo 3DS 2015 C-Stick Replacement: passo 3, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 3, imagem 2 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  4. Nintendo 3DS 2015 C-Stick Replacement, SD Card Reader: passo 4, imagem 1 %32
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
    Pergunte ao FixBot
    Comentar
  5. Nintendo 3DS 2015 C-Stick Replacement: passo 5, imagem 1 %32
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
    Pergunte ao FixBot
    Comentar
  6. Nintendo 3DS 2015 C-Stick Replacement: passo 6, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 6, imagem 2 %32
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
    Pergunte ao FixBot
    Comentar
  7. Nintendo 3DS 2015 C-Stick Replacement, Lower Case: passo 7, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement, Lower Case: passo 7, imagem 2 %32 Nintendo 3DS 2015 C-Stick Replacement, Lower Case: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
    Pergunte ao FixBot
    Comentar
  8. Nintendo 3DS 2015 C-Stick Replacement: passo 8, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 8, imagem 2 %32
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  9. Nintendo 3DS 2015 C-Stick Replacement: passo 9, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 9, imagem 2 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 9, imagem 3 %32
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  10. Nintendo 3DS 2015 C-Stick Replacement, C-Stick: passo 10, imagem 1 %32
    • Remove the four 3mm Phillips #00 screws.
    • Remove the three 3mm Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  11. Nintendo 3DS 2015 C-Stick Replacement: passo 11, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 11, imagem 2 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 11, imagem 3 %32
    • Pull up gently on power cable to loose it from the motherboard.
    • Pull the ribbon cable, connected to the mic, gently towards you with a pair of tweezers.
    • Lift the tab to free the large ribbon cable on just above the power connector.
    Pergunte ao FixBot
    Comentar
  12. Nintendo 3DS 2015 C-Stick Replacement: passo 12, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 12, imagem 2 %32
    • Pry the C-Stick from its plastic housing with the flat side of a spudger.
    • Lift the assembly gently out of the device from the battery connector at the bottom of the leftmost circuit board.
    Pergunte ao FixBot
    Comentar
  13. Nintendo 3DS 2015 C-Stick Replacement: passo 13, imagem 1 %32 Nintendo 3DS 2015 C-Stick Replacement: passo 13, imagem 2 %32
    • Flip the board over to reveal the connector for the C-stick's ribbon cable.
    • Lift the tab on the ZIF connector securing the C-Stick to the board.
    • Separate the C-Stick from the board.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Tyler Starr
Membro desde: 10/06/16
1.779 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 4-6, Livingston Fall 2016 Membro de Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Membros
Autoria de 46 guias
3Comentários do guia
What do I do if two of my screws were stripped when I got my system? I need to fix my cstick desperately but I cant get inside of my 3ds. Anything at all would help.
~Akiru
Darian Morales - Responder Compartilhar
Hello Akiru! Stripped screws can be a bugger, but you do have some options. I could outline some of your options here, but iFixit has a good article for this one. Go ahead and take a look at the article on iFixit titled "How to Remove a Stripped Screw", it should help you out.
Have a Good One.
Tyler
Tyler Starr - Responder Compartilhar
you do have the option of just ripping it out
Deo Padilla - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 20
Últimos 7 dias: 91
Últimos 30 dias: 324
Ao todo: 22,030
