Ir para o conteúdo principal
Nintendo 3DS 2015 Battery Replacement
O que você precisa
  1. Nintendo 3DS 2015 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
    Pergunte ao FixBot
    Comentar
  2. Nintendo 3DS 2015 Battery Replacement: passo 2, imagem 1 %32 Nintendo 3DS 2015 Battery Replacement: passo 2, imagem 2 %32
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
    Pergunte ao FixBot
    Comentar
  3. Nintendo 3DS 2015 Battery Replacement: passo 3, imagem 1 %32 Nintendo 3DS 2015 Battery Replacement: passo 3, imagem 2 %32 Nintendo 3DS 2015 Battery Replacement: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Tyler Starr
Membro desde: 10/06/16
1.779 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 4-6, Livingston Fall 2016 Membro de Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Membros
Autoria de 46 guias
6Comentários do guia
The link to the Nintendo store to buy a battery no longer functions.
David Clarke - Responder Compartilhar
My console has been off and without a battery for months now and I haven't been able to get a replacement battery until very recently, I replaced it just now and the orange led lights on (albeit for a short time) but the console won't turn on. The blue led lights up briefly then goes out again and the console remains off. Could it be something wrong with the console itself rather than the battery? Edit: Should I just leave it plugged in for a while even if the orange led doesn't stay on?
Leon J - Responder Compartilhar
I solved it by cleaning the contacts, reseating the battery and removing the microSD card. The SD card can then be put back in later
How's the battery life on it so far? I know you just posted 2 days ago, but I was just curious.
Will Reds - Responder Compartilhar
i bought one of these batteries but it’s slightly smaller than the original battery and and the charge does not last long, maybe 1-2 hours
Jessica V - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 70
Últimos 30 dias: 284
Ao todo: 12,583
