Ir para o conteúdo principal
Nintendo 2DS Battery Replacement
O que você precisa
  1. Nintendo 2DS Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
    Pergunte ao FixBot
    Comentar
  2. Nintendo 2DS Battery Replacement: passo 2, imagem 1 %32 Nintendo 2DS Battery Replacement: passo 2, imagem 2 %32
    • Hinge the upper rear panel upwards and outwards to remove it.
    Pergunte ao FixBot
    Comentar
  3. Nintendo 2DS Battery Replacement: passo 3, imagem 1 %32 Nintendo 2DS Battery Replacement: passo 3, imagem 2 %32 Nintendo 2DS Battery Replacement: passo 3, imagem 3 %32
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    Pergunte ao FixBot
    Comentar
Conclusão
46 outras pessoas executaram este guia.
Fina Beauchamp
Membro desde: 01/12/15
3.383 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 70-1, Forte Winter 2015 Membro de Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Membros
Autoria de 36 guias
7Comentários do guia
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Responder Compartilhar
This didnt help my problem
Artemy Matveev - Responder Compartilhar
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Responder Compartilhar
or maybe its just not working ludovic 🫡
Natalia Rabago - Responder Compartilhar
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 26
Últimos 7 dias: 213
Últimos 30 dias: 1,076
Ao todo: 63,885
