Ir para o conteúdo principal
Ninja Professional Blender BL660 Power Cord Replacement
O que você precisa
  1. Ninja Professional Blender BL660 Power Cord Replacement, Blender Base: passo 1, imagem 1 %32 Ninja Professional Blender BL660 Power Cord Replacement, Blender Base: passo 1, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Power Cord Replacement: passo 2, imagem 1 %32 Ninja Professional Blender BL660 Power Cord Replacement: passo 2, imagem 2 %32
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Power Cord Replacement: passo 3, imagem 1 %32 Ninja Professional Blender BL660 Power Cord Replacement: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Power Cord Replacement: passo 4, imagem 1 %32 Ninja Professional Blender BL660 Power Cord Replacement: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Power Cord Replacement: passo 5, imagem 1 %32 Ninja Professional Blender BL660 Power Cord Replacement: passo 5, imagem 2 %32
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 Power Cord Replacement, Power Cord: passo 6, imagem 1 %32 Ninja Professional Blender BL660 Power Cord Replacement, Power Cord: passo 6, imagem 2 %32
    • Check the connection between the power cord and the wires coming from the circuit board.
  7. Ninja Professional Blender BL660 Power Cord Replacement: passo 7, imagem 1 %32 Ninja Professional Blender BL660 Power Cord Replacement: passo 7, imagem 2 %32
    • Remove the plastic caps on the wire connectors with your hands.
    • Ensure that the connections are not loose, corroded, or desoldered.
    • If the connections are desoldered, loose, or corroded, re-solder them using the iFixit soldering guide.
  8. Ninja Professional Blender BL660 Power Cord Replacement: passo 8, imagem 1 %32
    • If the connections in the preceding step are good, check the connection of the wires to the circuit board.
    • If the connections are loose or damaged, the blender may not be getting power.
  9. Ninja Professional Blender BL660 Power Cord Replacement: passo 9, imagem 1 %32
    • Re-solder the connections using the iFixit Soldering guide.
    • Make sure you check the correct solder points since the wires are routed differently.
Conclusão
2 comentários
Hello,
I have a question. Do you know where can I buy the power cord for Ninja Blender. The model is BL 770. I have not found it anywhere. I also contacted Ninja Support by phone, but they don't sell this part of the Blender.
Denis Figueiredo - Responder
Excellent pictures and directions! this made the repair easy
Donald Beers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 9
Últimos 30 dias: 35
Duração total: 2,072
