Ir para o conteúdo principal
Ninja Professional Blender BL660 Circuit Board Replacement
O que você precisa
  1. Ninja Professional Blender BL660 Circuit Board Replacement, Blender Base: passo 1, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement, Blender Base: passo 1, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Circuit Board Replacement: passo 2, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement: passo 2, imagem 2 %32
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Circuit Board Replacement: passo 3, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Circuit Board Replacement: passo 4, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Circuit Board Replacement: passo 5, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement: passo 5, imagem 2 %32
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 Circuit Board Replacement, Circuit Board: passo 6, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement, Circuit Board: passo 6, imagem 2 %32
    • Using the Phillips #2 screwdriver remove the 4 screws (10mm long, 5mm wide) on the circuit board.
  7. Ninja Professional Blender BL660 Circuit Board Replacement: passo 7, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement: passo 7, imagem 2 %32
    • To give the circuit board further range of motion, remove the pictured zip ties holding the cables.
  8. Ninja Professional Blender BL660 Circuit Board Replacement: passo 8, imagem 1 %32 Ninja Professional Blender BL660 Circuit Board Replacement: passo 8, imagem 2 %32
    • Desolder the seven wires indicated from the circuit board.
    • For further instruction on sodering and desodering reference iFixit's guide.
    • To ensure the sodering of the correct wires, make sure to flip the circuit board over and confirm the wires that are being altered.
    • Soldering iron is hot. Handle with care.
  9. Ninja Professional Blender BL660 Circuit Board Replacement: passo 9, imagem 1 %32
    • Once the wires are cool to the touch, remove circuit board.
    • Remember to keep track of all cables removed to ensure their correct placement into the new circuit board.
    • Ninja Kitchen does not sell circuit boards. You will have to purchase one from a third party vendor.
Conclusão
3 outras pessoas executaram este guia.
8 comentários
Thanks for this. Where can I locate a vendor to purchase a circuit board?
Krystal Simpson - Responder
Hi, where do I find the circuit board please?
Daniel - Responder
Where can I get the circuit board?
nick.nemec - Responder
Anyone had any luck on finding the circuit board to buy?
Clayton Vieira - Responder
Excellent information, just need the circuit board or the schematics.
Santiago Antero - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 80
Duração total: 4,127
