Ir para o conteúdo principal
Ninja Master Prep QB900B button replacement
O que você precisa
    1. Ninja Master Prep QB900B button replacement, The Ninja Master Prep QB900B: passo 1, imagem 1 %32
      • Place the blender to the side.
      Pergunte ao FixBot
      Comentar
    2. Ninja Master Prep QB900B button replacement: passo 2, imagem 1 %32 Ninja Master Prep QB900B button replacement: passo 2, imagem 2 %32
      • Remove the two highlighted screws with a Phillips #2 Screw Driver
      • Gently pull off the top.
      Pergunte ao FixBot
      Comentar
    1. Ninja Master Prep QB900B button replacement, Button: passo 3, imagem 1 %32
      • Remove the highlighted screws.
      Pergunte ao FixBot
      Comentar
    2. Ninja Master Prep QB900B button replacement: passo 4, imagem 1 %32
      • Pull out the highlighted spring.
      • Now wash the button with soap and water, and follow the guide backwards to reassemble.
      Pergunte ao FixBot
      Comentar
Conclusão
Kamal Taha
Membro desde: 08/27/15
679 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Fall 2015 Membro de USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Membros
Autoria de 10 guias
2Comentários do guia
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
Stephen Filippone - Responder Compartilhar
turns out it was a security torx. how annoying.
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 2,375
