Ir para o conteúdo principal
Ninja Kitchen System Pulse Motor Replacement
O que você precisa
  1. Ninja Kitchen System Pulse Motor Replacement, Base Disassembly: passo 1, imagem 1 %32
    • Take out the three 15 mm Phillips #1 screws.
    • Remove the 15mm T10 screw.
    • Place the 4 screws on the magnetic mat.
    Pergunte ao FixBot
    Comentar
  2. Ninja Kitchen System Pulse Motor Replacement: passo 2, imagem 1 %32
    • Remove the gray base by lifting upwards and placing to the side.
    Pergunte ao FixBot
    Comentar
  3. Ninja Kitchen System Pulse Motor Replacement, Motor: passo 3, imagem 1 %32
    • Remove the three 15 mm Phillips #1 screws.
    • Place screws on magnetic mat.
    Pergunte ao FixBot
    Comentar
  4. Ninja Kitchen System Pulse Motor Replacement: passo 4, imagem 1 %32
    • Remove the motor by gently lifting up. Be careful with the cords, as they may be tangled.
    • This is the entire motor for the Ninja. If you have access to a spare motor, simply swap out the motors.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
DJ
Membro desde: 01/20/16
131 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 15-1, Remmell Spring 2016 Membro de USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Membros
Autoria de 5 guias
1Comentário do guia
Dear sir my ninga kitchen system 1100 (blender machine) motor rod is broken i need help to replace it where i can get the rod or repair shop near me thank you
Noman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 4,850
