Ir para o conteúdo principal
Nikon D90 Rear Display Buttons Replacement
O que você precisa
    1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: passo 1, imagem 1 %32 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: passo 1, imagem 2 %32
      • Locate the screws on both sides of the camera.
      • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
      • Be careful not to strip the screws.
      Pergunte ao FixBot
      Comentar
    2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: passo 2, imagem 1 %32 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: passo 2, imagem 2 %32 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: passo 2, imagem 3 %32
      • Use a plastic opening tool to separate the rear case from the camera.
      Pergunte ao FixBot
      Comentar
    3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: passo 3, imagem 1 %32 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
      • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
      Pergunte ao FixBot
      Comentar
    4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: passo 4, imagem 1 %32 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: passo 4, imagem 2 %32
      • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
      • Remove the ten 5.3 mm Phillips screws.
      • Remove the three 4.3 mm Phillips screws.
      Pergunte ao FixBot
      Comentar
    5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: passo 5, imagem 1 %32 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: passo 5, imagem 2 %32 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: passo 5, imagem 3 %32
      • Use a plastic opening tool to separate the LCD and metal plates from the casing.
      Pergunte ao FixBot
      Comentar
    6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: passo 6, imagem 1 %32 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: passo 6, imagem 2 %32 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: passo 6, imagem 3 %32
      • Use a plastic opening tool to separate the buttons from the casing.
      • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Membro de UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Membros
Autoria de 36 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 47
Ao todo: 3,295
