Ir para o conteúdo principal
Nikon D90 Flash Hinge Spring Replacement
O que você precisa
    1. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: passo 1, imagem 1 %32 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: passo 1, imagem 2 %32 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: passo 1, imagem 3 %32
      • Use a plastic opening tool to lift up the flash.
      Pergunte ao FixBot
      Comentar
    2. Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: passo 2, imagem 1 %32 Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: passo 2, imagem 2 %32
      • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
      • Be careful not to strip the screw heads.
      Pergunte ao FixBot
      Comentar
    3. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: passo 3, imagem 1 %32 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: passo 3, imagem 2 %32 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: passo 3, imagem 3 %32
      • Use a plastic opening tool and carefully pry open the top casing of the flash.
      • Then, lift off the top casing of the flash.
      Pergunte ao FixBot
      Comentar
    1. Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: passo 4, imagem 1 %32 Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: passo 4, imagem 2 %32
      • Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
      Pergunte ao FixBot
      Comentar
    2. Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: passo 5, imagem 1 %32 Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: passo 5, imagem 2 %32
      • Use a plastic opening tool and carefully pry up the spring arm.
      • Doing this with release the pressure of the spring.
      Pergunte ao FixBot
      Comentar
    3. Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: passo 6, imagem 1 %32 Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: passo 6, imagem 2 %32
      • Finish removing the screw holding the spring in place.
      • The spring can now be removed and replaced.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Grota
Membro desde: 10/16/14
598 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Membro de UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Membros
Autoria de 54 guias
2Comentários do guia
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
Ryad Arlan - Responder Compartilhar
My flash won't stay down. I think the piece that clips in to keep it closed may have broken. Is there a way to fix?
Linda Wick - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 48
Ao todo: 4,980
