Ir para o conteúdo principal
Nikon D5200 Screen Replacement
O que você precisa
  1. Nikon D5200 Screen Replacement, Screen: passo 1, imagem 1 %32 Nikon D5200 Screen Replacement, Screen: passo 1, imagem 2 %32 Nikon D5200 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Fully open the LCD panel so that its screws are easily accessible.
    • Remove the two 2.5 mm screws from the outside edge of the screen casing, and the two 3.5 mm screws from the inside edge.
  2. Nikon D5200 Screen Replacement: passo 2, imagem 1 %32 Nikon D5200 Screen Replacement: passo 2, imagem 2 %32 Nikon D5200 Screen Replacement: passo 2, imagem 3 %32
    • Pry open the plastic casing using the opening tool or by hand.
  3. Nikon D5200 Screen Replacement: passo 3, imagem 1 %32 Nikon D5200 Screen Replacement: passo 3, imagem 2 %32 Nikon D5200 Screen Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tool to pop up the latch holding the ribbon cable on the right side of the circuit board, and remove it.
    • Use the plastic opening tool to pry the ribbon cable on the left side of the circuit board up and off of its socket.
  4. Nikon D5200 Screen Replacement: passo 4, imagem 1 %32 Nikon D5200 Screen Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, unplug the smaller cable.
  5. Nikon D5200 Screen Replacement: passo 5, imagem 1 %32 Nikon D5200 Screen Replacement: passo 5, imagem 2 %32
    • Desolder the three small wires on the left side of the circuit board.
    • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
  6. Nikon D5200 Screen Replacement: passo 6, imagem 1 %32 Nikon D5200 Screen Replacement: passo 6, imagem 2 %32 Nikon D5200 Screen Replacement: passo 6, imagem 3 %32
    • Using a spudger, remove the display from its casing.
Conclusão
15 outras pessoas executaram este guia.
Alexander Corn
Membro desde: 08/26/15
1.319 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-1, Eyestone Fall 2015 Membro de USF Tampa, Team 3-1, Eyestone Fall 2015
USFT-EYESTONE-F15S3G1
4 Membros
Autoria de 5 guias
11Comentários do guia
Do I need to de-solder if I'm just replacing the window glass?
isaac - Responder
To isaac: no. The exterior glass is separate from the LCD.
Joseph Morris - Responder
Do you recommend the replacent for LCD sold on Ebay?
g_atki - Responder
Where did you find the replacement screen? The one I ordered that says it's for the d5200 is not the same as the one in it or in your pictures.
Heather Miller - Responder
How do you disconnect the multi-plug that is shown connected in image 4 and disconnected in image five? Does it unclip or slide out?
Amanda Bruyninckx - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 77
Ao todo: 13,296
