Ir para o conteúdo principal
Nikon D40 Viewfinder Replacement
O que você precisa
    1. Nikon D40 Viewfinder Replacement, Back Cover: passo 1, imagem 1 %32
      • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
      Pergunte ao FixBot
      Comentar
    2. Nikon D40 Viewfinder Replacement: passo 2, imagem 1 %32 Nikon D40 Viewfinder Replacement: passo 2, imagem 2 %32
      • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
      Pergunte ao FixBot
      Comentar
    3. Nikon D40 Viewfinder Replacement: passo 3, imagem 1 %32
      • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    4. Nikon D40 Viewfinder Replacement: passo 4, imagem 1 %32
      • While pulling the bottom down, remove the back of the camera.
      • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
      • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
      Pergunte ao FixBot
      Comentar
    1. Nikon D40 Viewfinder Replacement, Viewfinder: passo 5, imagem 1 %32
      • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
      • Be careful not to pull too hard on the ribbon cables.
      Pergunte ao FixBot
      Comentar
    2. Nikon D40 Viewfinder Replacement: passo 6, imagem 1 %32
      • Slowly push the upper body up until you see the frame of the viewfinder
      • Be careful while pulling the top camera body.
      Pergunte ao FixBot
      Comentar
    3. Nikon D40 Viewfinder Replacement: passo 7, imagem 1 %32
      • Use a spudger to keep the upper body separate from the printed circuit board.
      • Wiggle the plastic eyepiece out of the frame. This may require some force.
      Pergunte ao FixBot
      Comentar
    4. Nikon D40 Viewfinder Replacement: passo 8, imagem 1 %32
      • Remove the viewfinder with the plastic opening tool.
      • Do not push too hard while using the opening tool.
      Pergunte ao FixBot
      Comentar
    5. Nikon D40 Viewfinder Replacement: passo 9, imagem 1 %32
      • The viewfinder has been removed!
      Pergunte ao FixBot
      Comentar
Conclusão
Amy Chen
Membro desde: 01/23/14
193 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-19, Maness Winter 2014 Membro de Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Membros
Autoria de 31 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 48
Ao todo: 4,059
