Ir para o conteúdo principal
Nikon D3200 Memory Card Replacement
    1. Nikon D3200 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32
      • Locate the memory card compartment on the right side of the LCD screen.
      Pergunte ao FixBot
      Comentar
    2. Nikon D3200 Memory Card Replacement: passo 2, imagem 1 %32 Nikon D3200 Memory Card Replacement: passo 2, imagem 2 %32 Nikon D3200 Memory Card Replacement: passo 2, imagem 3 %32
      • Gently press and slide the grooved compartment door to the left.
      • Let go of the compartment door and it will swing open.
      • Insert the memory card imitating the diagram pictured outside the compartment door.
      • Make sure to push down once the memory card is inserted to lock it in place.
      Pergunte ao FixBot
      Comentar
Conclusão
12 outras pessoas executaram este guia.
Irene Huang
Membro desde: 09/08/14
720 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 1-3, Bruce Fall 2014 Membro de CSU Fullerton, Team 1-3, Bruce Fall 2014
CSUF-BRUCE-F14S1G3
6 Membros
Autoria de 24 guias
1Comentário do guia
Hello is this about replacing the memory card compartment or just the memory card? Apparently the memory card compartment is not maintining the memory, it’s not keeping it in the memor slot keeps popping back up. How do I fix this? Can I replace the housing?
Joseph Antonio - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 68
Ao todo: 5,536
