O que você precisa
Remove six 3 mm x 2.5 mm Phillips head screws from the bottom of the camera.
Remove three 3 mm x 5.5 mm Phillips head screws from the bottom of the camera near the battery cover.
Lift the battery cover and remove two 3 mm x 5.5 mm Phillips head screws as shown.
Remove the bottom cover.
Remove two 3 mm x 4 mm Phillips head screws from where the camera grip was just removed.
Remove one 2 mm x 3 mm Phillips head screw from the same location as above.
Remove one 3 mm x 5.5 mm Phillips head screw from the top right side of the camera shown.
Remove one 3 mm x 3 mm Phillips head screw from the top left side of the camera shown.
Gently lift the top of the camera up to separate it from the main body of the camera. At this point, it will still be connected via wires.
4 outras pessoas executaram este guia.
1Comentário do guia
Thanks for the guide. It was very helpful. I had problem with a shutter button. I have not replace it but disassembled and cleaned two tiny metal contacts inside, now my camera works well.
