Introdução
After removing the covering of the flash arm and it's components, remove the metal spring from it's hinge and replace it with a new one.
O que você precisa
Remove the two 2.5mm x 4mm Philips screws located directly under the flash.
Pop off the covering of the flash to reveal the flash arm spring.
7 outras pessoas executaram este guia.
