Ir para o conteúdo principal
Nikon Coolpix S9700 Memory Card Replacement
    1. Nikon Coolpix S9700 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: passo 1, imagem 2 %32 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: passo 1, imagem 3 %32
      • Power off the S9700 and situate it so that it is upside down.
      • Place your finger on the compartment door.
      • Gently push toward the front of the S9700.
      • The compartment door should spring open by itself.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix S9700 Memory Card Replacement: passo 2, imagem 1 %32 Nikon Coolpix S9700 Memory Card Replacement: passo 2, imagem 2 %32 Nikon Coolpix S9700 Memory Card Replacement: passo 2, imagem 3 %32
      • Locate the memory card. Be careful not to mistake it for the battery.
      • Push down on the memory card until it won't go down further. Don't push too hard to avoid damaging your camera
      • Release your finger and the card will pop up out of its compartment.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix S9700 Memory Card Replacement: passo 3, imagem 1 %32 Nikon Coolpix S9700 Memory Card Replacement: passo 3, imagem 2 %32
      • Grab your memory card with two fingers.
      • Gently pull up and your memory card will come out.
      Pergunte ao FixBot
      Comentar
Conclusão
Matt Staubus
Membro desde: 10/05/16
849 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 9-5, Lacy Fall 2016 Membro de USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 967
