Ir para o conteúdo principal
Nikon Coolpix S51c LCD Screen Replacement
O que você precisa
  1. Nikon Coolpix S51c LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32 Nikon Coolpix S51c LCD Screen Replacement, Back Cover: passo 1, imagem 2 %32
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c LCD Screen Replacement: passo 2, imagem 1 %32
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c LCD Screen Replacement: passo 3, imagem 1 %32
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c LCD Screen Replacement: passo 4, imagem 1 %32
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c LCD Screen Replacement: passo 5, imagem 1 %32
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
  6. Nikon Coolpix S51c LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32
    • On back of LCD screen, locate the three screws underneath the ribbon.
    • Remove each screw using your screwdriver.
  7. Nikon Coolpix S51c LCD Screen Replacement: passo 7, imagem 1 %32 Nikon Coolpix S51c LCD Screen Replacement: passo 7, imagem 2 %32
    • Take out the rectangular component on the side where the screws were.
    • Carefully, pry apart the screen from the back casing using the spudger.
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Ryan
Membro desde: 04/12/11
167 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 18-24, Garner Spring 2011 Membro de Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 2,701
