Introdução
In this guide, you will find instructions on how to properly remove the entire external casing of the camera. This guide will reveal the inner components of the camera. From here, you can replace the casing if it is broken, or access other internal parts of the camera.
Ferramentas
Peças
Nenhum componente especificado.
Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
There are 2 on each side, and 4 on the bottom.
2 outras pessoas concluíram este guia.
